03 DZL JET
Hi all 1st post & new member!
I have just bought a 2003 Jetta TDI with 125,000 Miles. ALH engine, 5 speed, full power,leather interior, sunroof, heated seats, bose sound system.
The bad.. It has a blown turbo & warped valves on 1# cylinder.
Previous owner noticed smoke in exhaust. Car was taken to a schmuck mechanic who said "valve cover was leaking so I replaced the gasket" last time I checked a leaking valve cover gasket won't put oil in the exhaust *cough*
Well on his drive home from the shop the engine began running rough and spitting oil out the exhaust.
So he then took the Jetta to a European Auto mechanic who upon inspection discovered blown turbo seals and the valves on #1 cylinder warped.
At this point the Jetta is put up for sale and I buy it for 1/3 of it's private party book value.
The turbo I will replace. The cylinder head will be rebuilt/replaced. Also will do water pump & Timing belt while I'm in there.
For you TDI guys & gals here I need tips & tricks, info common problems please
I am a 1st time VW Jetta Diesel owner and would like to pick your brains on these engines.
A bit about me I have 2.5 years of diesel experience on Nissan, Isuzu, Kubota, Deutz, John Deere engines.
And 10 years in Aviation on piston, turboprop & turbine engines so I know my way around an engine or two.
Thanks for the info!
