Phil Lewandowski
Hi all,
I recently got a '01 Jetta TDI and had been running great but I took a road trip to Wisconsin and on the way back to Cleveland today I had it gel up or ice twice. Once after 45 minutes on the road right in Green Bay and the second time an hour and a half later just outside Milwaukee. The first time I had it towed to a nearby dealer (I know...) and they said it had gelled so they replaced fuel filter and put in an additive and sent me on my way. Then an hour and half later...same thing. We had been driving through -11 to -17 degrees F.
While stranded the second time I threw in some diesel 911 in the tank and a little in the filter, but no dice. So it is towed and sitting in a auto garage here overnight right now.
Secondly, I had been using Stanadyne's standard year round performance additive, which I had been reading is a demulsifier and may actually have been adding to the problem with icing and not necessarily gelling. So since this tank is about 1/2 full still with a mixture of fuel Standadyne and diesel 911 would the 911 help with the issue the Stanadyne might be causing?
So I am just looking for some advice in keeping it running after I would assume it "de-thaws" in the garage overnight before they look at it tomorrow morning.
Thank you all very much for your help!
Phil
Phil
