Joe Kelsch
I just got a 2000 Golf TDI. It had 172k on it when I bought it. I replaced the air filter (which was black) and fuel filter (which seemed like original). Since I've changed the fuel filter I noticed a fuel leak dripping off of the oil drain plug. I couldn't find the leak anywhere till 530 this morning on my way to work. The car started vibrating under load. Seemed like a miss and it was. The nut on #2 fuel line going into the injector is cracked, spraying fuel everywhere. I drove another few miles to get to work where I tightened it up a little. So what I need is a new fuel line. The only one I found is $70 through partsplaceinc.com Are there any cheaper ones out there?
