50harleyrider
- Joined
- Jun 16, 2007
- Location
- charleston,wv
- TDI
- 2005 B5.5 TDI/geared BSM, BV43A turbo,stage 2 TDTUNING. 2005 5sp manual passat tdi stage 2 tdtuning,BSM delete. 2015 Passat TDI 6sp manual.
I have upgraded to a vnt 17/22,pp764 nozzles and a pd150 intake and wanted some chip advice. I have an ecu from another 03 golf with an RC4 tune in it. Is that a good choice? Is it plug and play? I was concerned it was VIN locked but hopefully by changing the ecu ,that won't be a problem. I'm running a Malone 1.5 now in the car which I know won't let the turbo go above 19 psi. What is a good Malone tune for my setup? Better exhaust, eurojet SMIC and 3bar MAP sensor are in the works. My engine has 210k miles on it and runs good so should I beware of anything with that? A Southbend Endurance clutch setup is also coming soon. Approximately what HP and torque will I have?
