Whitbread
Vendor , w/Business number
I have both turbo gaskets water jetted in .040" copper on the shelf.
How much shipped... would you be able to get the nuts, exhuast gasket and such cheaper and send all together? to support you as a vender....I have both turbo gaskets water jetted in .040" copper on the shelf.
I only have the copper gaskets for the turbo, $18 ea. The nuts are the same as all the tdi's use, M8. I'd just ring up IDParts or Bora Parts for the nuts and cbea manifold to head gasket. I know Peter has sold them.How much shipped... would you be able to get the nuts, exhuast gasket and such cheaper and send all together? to support you as a vender....
X2. You already had one premature Spec fail, why go there again?Those wear out just as fast if not even faster than the sintered disc you used previously. When the car is daily driven the best option is SRE or SBC set wit organic disc. I'm pretty damn sure those will hold more than enough for your FWD car.
If you don't mind a bit of noise I will have a setup ready soon that will take anything you can throw at it.Put 1500+ miles on since stock clutch put back in... Still running strong.. I think I am going spec twin unless someone proves otherwise with better combo
The clutch i displayed above was a Sachs SRE silent disc that bluewater performance ordered and installed for me...X2. You already had one premature Spec fail, why go there again?
My bad. Either way, don't run a spec. I've changed out 10+ of them prematurely in everything from VW's, DSM's, and hondas.The clutch i displayed above was a Sachs SRE silent disc that bluewater performance ordered and installed for me...
If the shop doing the install is asking for a backlash measurement on an 02M/02Q for an lsd install, they shouldn't be the job at all. The important measurement is .008"-.013" of differential bearing preload. If they ask how to measure it, find another shop.does anyone know what backlashing is required for LSD install...
see How to: 02M/02Q LSD Install post #19Does anyone have steps to backlash the gears for LSD install?
I read that but no backlash info
I need help, I want to keep the PDE downpipe i bought in one peace, So i am looking for help on finding the correct vband adapter that mates to the stock vband. So i want to make an adapter from GTB flange to VW vband so i can just bolt it up to the PDE downpipe and not destroy it.
i wish.. im way on the west coast also parts keep getting lost from UK and Germany when i order stuff... im on my 4th claim ordering from europe already... i swear the ups guy is building my big turbo setup on his car!!!Are we gonna see this thing on the dyno at TDIFest or what?
