Toyotaguy
I am doing a 2.0L common rail tdi with Piezo injectors. I am using a Nira Piezo standalone ecu to control the engine. Just getting started on this. My plans are to run bi turbos. a vnt17 as the small turbo and a fixed vain turbo aurora 2000 as my atmospheric charger. Since this engine is fairly advanced i decide to challange my self and learn more advanced engine control.
Plan:
Control Piezo injectors
-Figure out how they are driven
-voltage and amperage max
-so the piezo crystals last
Control the common rail pressure.
- Take control of the volume control valve on the cp4.1 pump as well as the pressure relief valve on the rail it self.
-Take control of pressure spikes in the rail to get a better combustion
Monitor The 0-5v cylinder pressure sensors to aid in optimal combustion.
- This will help with control of Pilot injections and Main injections
- Quieter engine noise
- More efficient power.
-Stable cylinder pressure
Computer Control of Bi turbos
-Install speed sensors in turbos
-control variable VNT17(should be easy
- Install waste gate that will bypass VNT17 and redirect energy to the atmospheric turbo(computer controlled)
- Install bypass valve on high pressure side to low pressure side (computer controlled)
-No emmisions parts
First thing i will need to do is get as much data as possible.
Connector pin outs
Voltage and amperage (wave form the piezo injectors need)
Duty cycle of the volume control valve(normally open)
Duty cycle of pressure control valve
pressure range of glow plug pressure transducer as how fast it reacts
-Pressure range to voltage
Data on all sensors that i will use.
air flow sensor (heated Film)
Fuel temperature
coolant temp
Cam and crank data
boost pressure sensors i will be running two for data
-atmospheric turbo pressure and high pressure turbo pressure after inter cooler.
egt sensor 5 one for each cylinder and one for the hot pipe between the two turbos
2 back pressure sensors off a 6.7 cummins one for drive pressure on high pressure turbo and 1 for the atmospheric turbo
barometric pressure sensor
ambient air temp sensor
I have alot to learn about the 2.0L TDIs but if any one has any data that would be useful. I will be getting all the data that i can. I just got my engine it is a 2009 CR 2.0L and a Nira standalone. I will be putting this in a Toyota Pickup. I love the capability of the common rail system on these engines. The sky the limit for diesel tech i think that the latest common rail tech is only the start to a better way of controlling a simi control combustion process. It can only get better. Thanks.
Plan:
-No emmisions parts
Connector pin outs
Fuel temperature
coolant temp
Cam and crank data
