Franko6
Vendor , w/Business number
Having trouble getting that promised cam?
NO problem here... We have all our cams in stock and ready to deliver. We have a steady supply of cams being manufactured and our orders are being filled.
For the cams installed, many are getting excellent results. Several people are achieving higher fuel economy than with the stock PD cams.
Also, we will soon be offering CNC'd semi's.
A 'semi cam' is a partially ground cam. In this case, the cam journals have been finished, but the valve and injector lobes are uncut, hardened steel forged blanks.
CNC cam grinding machinery allows grinding a cam without the need to physically manufacture a master profile. Instead, cam profiles are digitally stored. This improves the ability to make alterations and eliminates the cost and problem of manufacturing and storing cam master profiles.
Also, CNC machining takes away the 'human element'. Each cam is manufactured start-to-finish without any more intervention than the operator setting the cam into the machinery and hitting the 'Start' button.
Watch for future announcements!
