Ton
I can't get the spring clamps put on my air line after the turbo. Do I need a special tool?
only if you work on German cars a lot.are worth their weight in gold.
Borrow a set and then do an ALH timing belt... you may never be able to go back to channel-locks again, especially for the lower intercooler hose.but never bought them
Yeah, I have no idea how folks could do that one without one of these tools!Borrow a set and then do an ALH timing belt... you may never be able to go back to channel-locks again, especially for the lower intercooler hose.
Where do you buy spring clamp pliers? Snap-on truck?
Got mine from idparts. They are ratcheted which helps a lot. I still use pliers for the smaller clamps in tighter surroundings.Where do you buy spring clamp pliers? Snap-on truck?
