2000MKIV
My MK4 Jetta has the Monsoon single DIN stereo, which is amplified and comes with a 6-disc CD changer in the trunk.
Time has moved on and I want to play MP3s from an MP3 player or directly from USB stick or flash card.
I have tried:
1. Tape adapter to play MP3: no go, lousy quality, only low volume with lots of static
2. Grom Aux input adaptor that plugs into the CD connector on the back of the radio: no go, same as tape adapter
3. FM transmitter: no go, same low volume, and lousy sound problem
I think I have exhausted all options for adding aux input other than soldering an aux input directly to the stereo's circuit board. I expect the sound again to suck, so I am hesitant to try that option.
I am now looking at replacing the Monsoon factory. I don't want to spend more than necessary. Can I keep the amplifier and the original speakers?
On crutchfield.com I see many stereos that are compatible with my 2000 Jetta, but they do not mention anything about these stereos being compatible with the Monsoon amplifier or stereo. Obviously, I can ask them, which I will do.
Before I do that, I would like to get any input from those of you who have successfully installed an aftermarket stereo. What brand and model did you use?
Also, does the aftermarket stereo affect some vehicle functions? I am thinking of the alarm system (confirmation honk) and interior lights, since the vehicle uses CAN bus, unless I am mistaken.
I appreciate any input.
I have tried:
