I did an auto-scan. My car is chipped to Rc4, could the program be the problem?
Saturday,14,July,2018,12:48:08:16763
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.1.2 (x64)
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: 3VWSP69M72M064787 License Plate:
Mileage: 603880km-375233mi Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWSP69M72M064787 Mileage: 603880km-375233miles
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 FD
Component: RC4f EDC G500SG 4102
Coding: 00002
Shop #: WSC 00066
VCID: 57A350B9B54C1FFC36-4B00
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 3177CE21AB6821CC98-515A
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 F
Component: 04 AIRBAG VW6 0202 0004
Coding: 12340
Shop #: WSC 00066
VCID: 3A65E90D261EE29429-515A
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 M
Component: KOMBI+WEGFAHRSP VDO V58
Coding: 07232
Shop #: WSC 07228
VCID: 3275C12DFE6E1AD4E1-515A
3VWSP69M72M064787 VWZ7Z0A4056948
2 Faults Found:
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: 70F10B2530E268C4D7-515A
1 Fault Found:
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 00066
VCID: 3763F039150CFFFCD6-4B00
Subsystem 1 - Part No: 1C1959801A
Component: 1H Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C1959802A
Component: 1H Tõrsteuer.BF KLO 0002
Subsystem 3 - Part No: 1C0959811A
Component: 1H Tõrsteuer.HL KLO 0002
Subsystem 4 - Part No: 1C0959812A
Component: 1H Tõrsteuer.HR KLO 0002
3 Faults Found:
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
00931 - Locking Module for Central Locking; Rear Right (F223)
End-------------------------(Elapsed Time: 05:49)--------------------------
