Gus3
I am in the process of helping a neighbor who has a 96 TDI Passat. What it is not doing is starting will not turn over I get no rotation of the starter.
What I have tested was the control plug at the starter (black/red) wire no power with the key to start. Then I moved back to the clutch switch (brown / red/white) and no power with the key to start.
Should I be looking for a fuse or relay that provides power or do I go directly to the ignition switch?
I have no experience with VW but a lot of experience with Jaguars. I am a little handy with tools and do my best to find the problem and why.
If you could give me a little guidance it would be greatly appreciated.
Gus
www.jagrepair.com
Gus
www.jagrepair.com
