grimlock
I plugged my fifth injector hose a long time ago. I want to remove the solenoid & etc, to keep my engine compartment more "clean" looking....
I read one or two posts in the past stating to use a 10 or 15 ohm resistor w/ 10W rating. If need be I could parallel a couple 30ohm resistors for even more power headroom... I have access to various "large" power resistors, but why such a high power rating?
If I removed the solenoid without putting in the resistor will the CEL come on?
My engine had the recall done quite awhile ago, my ECU ends in GQ.
Richard
Richard
