freakwithracket
Update: Some interesting things here. I solved my issue with common grounds causing the instrument cluster going crazy. I did this by grounding the voltage regulator on the drivers side fender. I also decided to not ground out the switch light. I'll just remember which way is on.
I did not install the second diode. Well, I tried, but it turns out that with the diode causes a voltage drop, from 4.98V to 4.3V, which it turns out is enough to not make the GP relay kick on. It does not seem to be an issue though.
Which brings me to the interesting part. With the key out of the ignition, and the manual switch turned on, the ST line reads 4.98V. Exactly as it should. However, the glow plugs will not turn on because the ignition switch is not on, which makes sense. So, with the ignition switch on and the manual switch off, there is no voltage on the ST line. But, with the ignition on and the manual switch on, there is not 4.98V as there is when the ignition off, but rather there is 11.06V....I don't understand that at all. I tested the ground from the regulator with both switches on and it had 7V. I am somewhat confused.
None the less, the manual system seems to work with the exception of the CEL that occurs. So does anyone have any ideas on how I could pulse my signal to the GP relay instead of a constant signal. I suppose the thing would be to send the pulse at a rate at which is less than the ECU "time out".
