spiksander
Hi, this is my first post here
I have a 2011 Mark 6 TDI 1.6 litre with 48k km on the clock. A couple of weeks ago I took it for a regular lubrication service at the local VW dealer. I also told them that lately the car was starting a bit rough and sometimes the rev counter would 'hunt' for the idle range when starting from cold. A couple of hours later they phoned phoned to inform me that they found metal bits in the fuel filter and this would require the replacement of the whole fuel system.. pump, injectors fuel lines at a cost of 5200 euros. They told me that the cause was the fuel quality, which is a problem since we don't have a lot of choice in Malta when it comes to fuel. We have fuel imported by Enemalta which technically complies with the EN 590 standard.
I have searched these forums and read about HPFP failures due to low fuel lubricity, but from what I'm able to understand, the biodiesel content in Euro EN 590 diesel should tackle that.
Anyways, to keep this short, I took the car to local VW specialist yesterday for a second opinion and we checked the fuel filter (since the dealer did not replace it). We did find small glittering metal bits in the filter but the specialist told me that the amount is not concerning him and appears to be normal wear and tear. The concern was some slimy sediment which he think was caused by contaminated diesel.
We then proceeded by replacing the fuel filter, checking for any fault codes (no fault codes found) and took the car for a spin. The car does make a sort of knocking sound (reminds me of old transit vans) when under pressure. I always thought this was normal since it made that sound since I can remember. The VW specialist told me that the problem was with the injectors, which needed to replaced at a cost of around 1500 euros parts and labour.
The question I have is whether it is safe to replace the injectors only. I do not want to ruin another set of injectors due to HPFP disintegration.
I was wondering if anyone had a similar experience. I have attached a photo of the fuel filter - note the sediment on the right hand side.
Any comments appreciated. Thanks in advance
