Ol'Rattler
When there is a timing failure, usually, it is because a roller, tensioner or water pump failed that wasn't changed at the last T/B change. Almost never is a timing failure caused by the belt.An inspection means it looks good right at that moment. It could break anytime after that. How many times have I read here that the looks of a belt (TB in particular) give no indication as to how serviceable it still is.
A T/B, if changed at the proper interval, will appear to be completely serviceable when you remove it. A bad idea, but just the T/B will last to about 150% of it's service life if none of the other components in the timing path fail.
If you don't want replacement parts that could "fail at any time", stop buying CRAP (Chinese Replacement Auto Parts)............
