There is a sticker affixed to the timing belt cover. It will have the code and serial number printed on it, with a bar code. The same serial number is stamped onto the block, but it may have corroded away too much. The block stamp is located near the transmission/oil pan joint.
Additionally, there is a build specification sticker that is supposed to be affixed to the spare wheel well, as well as in the owner's manual, general section if I recall correctly. In the radio section, the original dealer should have affixed a radio code sticker. This build spec sticker has the engine code, transmission code, and paint code. Below the main codes are PR numbers for all variable options, such as suspension class, types of mirrors, wheels, and so on. Some build stickers were misprinted and are missing a few codes.
