Old August 10th, 2015, 14:55   #1
TDIER
Fuel Economy: 38 city, 48 Hwy
Question 2006 Jetta TDI, DSG Rattle help Please!
Folks,
Need your help...
The DSG seems to be making a grinding noise ( seems more of a reciprocating noise) only at certain loads / speeds. the noise is more related to engine RPM than road speed.
Cannot be duplicated in park, no noise when the car is in motion and in neutral.
Had the drivers side wheel bearing changed recently. Mechanic thinks it the bearing on the differential drive shaft??? It has started to jerk a bit coming to a stop. The rest of the tranny shifts fine.
Any help on what this could be, is greatly appreciated.
Madan
2006 Jetta TDI 178K, DSG ( Helga)
TDIER is offline   Reply With Quote
Old August 10th, 2015, 21:02   #2
banshee365
TDI(s): '13 Passat
Inform yourself on dual-mass flywheel issues with the 2006 car's. It's a matter of when not if. Check your alternator pulley to rule that noise out, it sounds a lot like a failing DMF. IF you find the flywheel to be the cause of the noise get it replaced ASAP. Also, it sounds to me like you need to find another mechanic that's familiar with TDI's.
banshee365 is offline   Reply With Quote
Old August 10th, 2015, 23:20   #3
MyAvocation
MyAvocation's Avatar
I agree with Banshee. Forget the CV joints (so called diff drive shaft), as it moves at a different rate than motor.
"Never trust Internet quotes." - John F. Kennedy
MyAvocation is offline   Reply With Quote
Old August 11th, 2015, 13:51   #4
TDIER
gentlemen,
Thank you so much for your input.... have a update on the car.
Had a spirited (but civil) conversation with the mechanic on the DMF.
Car on the lift tranny in neutral, engine off. Grinding noise when the drivers wheel is turned. Is this a good test to rule out the DMF failure as the DMF is not in operation now.
Checked the alternator pulley...no issues as it was replaced 8 mo ago.
He claims that it is still probably a bearing issue, he has searched all his resources and VW does not sell any spares for the DSG. Any part sources that I can call for spares??
Latest symptom car jerks when coming to a full stop.
I am taking it to another tranny shop for a second opinion.
Should I be looking for a rebuild tranny? any help is appreciated.
Old August 11th, 2015, 22:05   #5
Mrrogers1
Fuel Economy: Never high enough but always trying for more.... (See signature)
Originally Posted by TDIER View Post
gentlemen,
Bearing as in wheel bearing?
Mrrogers1 is offline   Reply With Quote
Old August 11th, 2015, 23:56   #6
MyAvocation
Yeah, that doesn't compute... He said frequency was RPM based, not wheel.
I am more familiar with wheel bearing issues than wish to. Best way to diagnose without removing parts is to wait until they progress louder, then put the car on a rack or 4 jack stands, start motor and put in drive. For best results have someone increase speed, then put a stethoscope or long screwdriver against the hub or knuckle and listen. Do same on opposite wheel and compare.
Old August 12th, 2015, 19:33   #7
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
North Carolina has many TDI Gurus. Go to one of them. Why would you go to a tranny shop? You get your teeth cleaned at the proctologist?
2015 Golf SEL. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is online now   Reply With Quote
Old August 18th, 2015, 19:36   #8
osesu96
Fuel Economy: 50.2 / 45.8 / 43.2
If you are in Asheville, you should go see Daniel Grindstaff. He did enough work on my 2 TDIs back when I lived in NC to know that he knows what he's doing in the TDI world.
http://forums.tdiclub.com/showthread.php?t=350157
2004 Jetta TDI GLS 5spd, RC2, Ventectomy, Phatbox, .681 5th , 'WD Collar Mod', VNT-17, 148k miles
2006.5 Jetta TDI "Diesel Edition" 125k miles
osesu96 is offline   Reply With Quote
2006 jetta tdi 1.9 rattle in oil pan smit5011 VW MKV-A5 Golf/Jettas 18 March 17th, 2013 18:03
bell type rattle at low RPM 2006 Jetta TDI monkeytrader TDI 101 7 March 8th, 2013 07:18
2006 Jetta TDi DMF DSG replacement - clunk rattle ecaddy TDI 101 12 March 20th, 2012 06:06
2006 Jetta TDI w/DSG mhaaksma TDI Cars for Sale/Wanted 0 January 29th, 2011 11:05
2006 VW Jetta TDI (BRM) 75k Pop or rattle noise kosamatic TDI 101 7 May 8th, 2010 21:17
Page generated in 0.10730 seconds with 11 queries
[Output: 86.33 Kb. compressed to 74.48 Kb. by saving 11.85 Kb. (13.73%)]
