treue
Anyone happen to have the AC delete belt part number? My local parts store is claiming ignorance without a number. Thanks.
That is right. I am not sure but I think bracket for alternator ,A/C and P/Steering pump is not same either. NONE of US models did not come with out A/C . You may want to try some Canadians models and see or if you have some one in Europe .ymz said:The routing for that non-AC belt is completely different than for the "normal" ALH engine with AC... (I believe the power steering pump is where the AC compressor is on your car...)
I don't think this particular belt will work, and I have no idea how you'll be routing it... hopefully someone who has done this before will chime in... soon...
Good luck!!!
Yuri
