Hello to all again. With all of this time off(obviously non-essential existence), I managed to pull the trans out of the $300 Jetta and put in the new DMF flywheel/clutch rep-set. This trans has the early shift tower assembly, and it was a new experience taking it apart. This assembly has a plastic cover with a tube shape extension that houses some sort of actuator for the reverse switch. I didn't look at it closely until putting things back together, but I noticed then that there is nothing in the tube to actuate when reverse is selected. I'm assuming something is missing. Does anyone have any idea what is supposed to be inside of this cap to actuate the reverse switch? The shift tower appears to also have a newer style, spring loaded, ball type actuator like the newer shift towers, but it is capped off and is pointing toward the rear of the engine. What do you all know about these odd shift tower setups? Does this shift tower have any name or type of identification? Thanks for anything you have to add.
