ky_tdi
I want to delete the EGR on my 04 Jetta Wagon and cannot find a straight answer on the web if I need to tune the ECM after removing the EGR or not. Does anyone here have any experience with EGR delete on MK4 jettas?
And, it's my understanding you can't reduce it at all on a BEW? Could be wrong... wouldn't be the first time.You can reduce EGR flow with VCDS, but you cannot "turn it off."
I would have to agree with this. My EGR is fully removed (valve is gone, cooler is gone, hoses bypassed, tuned out) and I don't think the engine warms up any slower.From what I've read and been told, PD motors get up to temp the same or faster with EGR deletes. From personal experience, ALH engines suffer from longer warmup without EGR's.
My BEW with the egr turned off seems the same, but I'll be removing the egr system soon so I'll find out.
There are 2 motors on the EGR and intake system. You leave the ASV operational as its the butterfly at the front of the intake. As I've read, if you have a 5/6 speed, the ASV isn't needed.I'm currently searching the forum for answers, but I want to do an EGR delete at the same time I have my timing belt changed and intake manifold cleaned. I'm a little hesitant to doing a delete mainly because I want to keep the ASV operational. If I read correctly before, the ASV is part of the EGR system and doing an EGR delete will remove the ASV. Can some shed some light if that is correct, and if so, is there a way to do it while keep the ASV?
Thanks. Feel free to link to the answer or message me. I'm still searching.
The ASV and EGR are separate on the BEW. You can completely remove everything EGR related and not touch the ASV and have it still functioningI'm currently searching the forum for answers, but I want to do an EGR delete at the same time I have my timing belt changed and intake manifold cleaned. I'm a little hesitant to doing a delete mainly because I want to keep the ASV operational. If I read correctly before, the ASV is part of the EGR system and doing an EGR delete will remove the ASV. Can some shed some light if that is correct, and if so, is there a way to do it while keep the ASV?
This is all exactly what I needed to know. I have an 05 wagon so its the BEW. Thanks a lot everyone.On the BEW it's a worthwhile endeavor to remove the egr and cooler.
It's a cheap mod, but it is very difficult to get the cooler off, you will almost regret doing the hardware based delete of the EGR.
- Flex pipes like to crack, EGR delete costs half the cost of a new flex pipe
- If and when your stock turbo goes and you want to upgrade to the VNT-17, you wont have to spend money on an EGR adapter to work
- Less vacuum lines to worry about cracking, or coming undone.
Also if and when you choose to do the hardware delete CONFIRM whoever you bought the kit from sent you a BEW kit, and not a BRM kit. The BRM has a smaller block off plate for the intake manifold.
I learned his the hardway when aarodriquez store sent me a BRM kit by mistake, and was left with an inoperable car for 2 days while I waited for next-day shipping for the proper part.
Great. thanks for the link.I used this EGR delete kit: http://www.ebay.com/itm/VW-TDI-MK4-...ash=item540da15821:g:ys4AAOSwJQdW-6io&vxp=mtr
Noisier? What kind of noise? I don't remember mine making a difference but probably didn't listen close enoughI used that one too. Funny thing, I put the EGR valve back in, car was a lot noisier inside the cabin without it and it actually seemed to make less power.
There was a slight sound increase for mine as well when I did the delete. I attributed that to the fact the 4th runner on the intake manifold always flowing more air, instead of being toggled while the egr cycled.Noisier? What kind of noise? I don't remember mine making a difference but probably didn't listen close enough
Way more intake noise, and very noticeable. I did the EGR removal and then hit the coke, going up some of those hills was almost unbearable for cabin noise, whereas same trip before, drive it alot, was much quieter with the EGR valve in. Doesn't matter anyhow, putting a Passat intake on with the race pipe,Noisier? What kind of noise? I don't remember mine making a difference but probably didn't listen close enough
