lmoretti
EDIT: Forgot to mention, this is a 2006 Pkg 1 with the premium audio.
Broke down and bought a copy of VCDS to try to fix this. Log is cut & paste below.
Here are the top candidates I think:
1) Parking Light Front Right Electrical Fault - Intermittent
2) Radio Control Module Defective
There are a lot of "Implausible Signal - Intermittent" and "Voltage Low" errors. Should I clear all the codes to eliminate the issue of my battery going low, keep it charged for a few days and see what comes back?
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72 7D
VIN: 3VWST71K66M024167 Mileage: 170000km-105633miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 1010
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H02--- Serial number: VWZ7Z0F4156851
Coding: 0050071
Shop #: WSC 00066 000 00000
VCID: 63EB560FA23EBF2603-8036
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73CB264F12DE2FA673-8026
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 FQ
Component: Climatic PQ35 120 0606
Shop #: WSC 00000 000 00000
VCID: 78D111630BB84CFE46-802C
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 P HW: 3C0 937 049 P
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000422089
Coding: 14018E234004150007140000001400000008730B5C0000
VCID: 364DDF5B412C7A8E94-8062
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 030806 020 0501
Coding: 00038805
Shop #: WSC 00066
1 Fault Found:
02395 - Parking Light Front Right (M3)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 60
Reset counter: 193
Mileage: 165807 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.70 V
ON
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F6017705
VCID: 2A75FB2B85942E6E00-807E
2 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 144
Mileage: 169783 km
Time Indication: 0
Date: 2000.00.00
Time: 04:59:30
01304 - Radio
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 31
Mileage: 167585 km
Time Indication: 0
Date: 2000.00.00
Time: 22:09:28
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 Q HW: 1K0 909 605 Q
Component: 6A AIRBAG VW8R 033 7900
Revision: 04033000 Serial number: 0038LD09EATL
Coding: 0013889
VCID: 3A55CB6B75349EEE70-806E
Subsystem 1 - Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Subsystem 2 - Serial number: 6332MSME0E601B5BJ
Subsystem 3 - Serial number: 6342MSME1033610E0
Subsystem 4 - Serial number: 6351HSME0A1B592DI
Subsystem 5 - Serial number: 6361HSME0A204D5FH
Subsystem 6 - Serial number: 63727SME0A301C2D1
Subsystem 7 - Serial number: 63827SME0A244A1B3
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AR HW: 1K0 953 549 AR
Component: J0527 035 0070
Coding: 0000021
VCID: 0225738B5D64162E68-8056
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 953 J HW: 1K0 920 953 J
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4156851
Coding: 0023203
Shop #: WSC 02645 444 58693
VCID: 3245E34BAD4466AEB8-8066
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 3
Reset counter: 184
Mileage: 0 km
Time Indication: 0
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001065271939
Coding: 3DBF0B6007001002
VCID: 2C79FD338F60305EF2-8078
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 169783 km
Time Indication: 0
Date: 2000.00.00
Time: 01:02:14
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1610
Shop #: WSC 02645 444 98482
1 Fault Found:
01176 - Key
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 147461 km
Time Indication: 0
Date: 2000.00.00
Time: 17:44:09
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1125
Revision: 12006001 Serial number: 00000073368722
Coding: 0001205
VCID: 3B5BCE6F7A0EA7E66B-806E
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Freeze Frame:
Fault Status: 00111000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 182
Mileage: 0 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
VCID: 3449E5535750689EAA-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: KSG PQ35 RDK 051 0215
Revision: 00051000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DCA0
VCID: 74C9255317D0289E6A-8020
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1125
Revision: 12006001 Serial number: 00000503668723
Coding: 0001204
VCID: 3C59CD737F00A0DE62-8068
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio DE2 145 0175
Revision: 00145000 Serial number: VWZ4Z7F2121924
Coding: 0010400
VCID: 24691513E7B0F81E3A-8070
3 Faults Found:
00668 - Supply Voltage Terminal 30
00003 - Control Module
014 - Defective
01305 - Databus for Infotainment
014 - Defective - Intermittent
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12004001 Serial number: 00000000225468
Coding: 0001168
VCID: 3E5DC77B691CB2CE4C-806A
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0420
Coding: 0100101
1 Fault Found:
00625 - Vehicle Speed Signal
Freeze Frame:
Fault Priority: 4
Fault Frequency: 255
Reset counter: 184
Time Indication: 0
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12004001 Serial number: 00000000219065
Coding: 0001168
VCID: 3FA3BA7F6E16BBC647-806A
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D7FF037B47A3956E5-8078
End-------------------------(Elapsed Time: 01:21)--------------------------
Coding: 0050071
Revision: 00H11001
Coding: 0021122
1 Fault Found:
Coding: 00038805
Shop #: WSC 00066
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 60
Reset counter: 193
Mileage: 165807 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.70 V
ON
ON
OFF
OFF
OFF
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 144
Mileage: 169783 km
Time Indication: 0
Date: 2000.00.00
Time: 04:59:30
01304 - Radio
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 31
Mileage: 167585 km
Time Indication: 0
Date: 2000.00.00
Time: 22:09:28
Coding: 0013889
Coding: 0000021
Coding: 0023203
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 184
Mileage: 0 km
Time Indication: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 169783 km
Time Indication: 0
Date: 2000.00.00
Time: 01:02:14
1 Fault Found:
01176 - Key
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 147461 km
Time Indication: 0
Date: 2000.00.00
Time: 17:44:09
Coding: 0001205
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 182
Mileage: 0 km
Time Indication: 0
Coding: 0001204
Coding: 0010400
3 Faults Found:
014 - Defective
Coding: 0001168
Component: RDK 0420
Coding: 0100101
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 184
Time Indication: 0
Coding: 0001168
