SFHGolfTDI
- Joined
- Nov 3, 2003
- Location
- Ventura, CA
- TDI
- 2002 Jolf GLS TDI - Reflex Silver (purchased 2011) | Previously: 2001 Golf GL TDI - Indigo Blue (sold 2005)
I got my ALH tuned by Kerma a few weeks ago. Its my first mod, and overall I'm very happy with it. Charlie made me two tunes and my stock tune switchable in VCDS (once my file is loaded on to ECU, I can use the auto, manual, 4-mo soft coding in VCDS to switch).
But I wanted some feedback about my 03 and 011 logs @ WOT. I think they look good overall, no overboosting at all. But I do get a dip (about 200 mbar) after my initial spike even though there is no overboosting. Kerma/ Charlie's recommendation is to lengthen the actuator rod if I want to even it out more.
The first two graphs are from the same tune, and the second two are from the more aggressive tune. Note: For all my logs, the duty cycle never gets above the low 60s (at the initial spike) and is usually in the mid 50s in the 3000-4000rpm range.
What I have done:
Should I:
Tune 1, first run (dips to 1978 mbar when specified is 2193).
Tune 1, second run (dips to 1989 mbar when specified is 2193)
Tune 2 (more power), first run (spikes to 2264, dips to 1978, specified 2193)
Tune 2 (more power), second run probably in 4th gear (dips to 1938, specified 2193)
What I have done:
- tested all vacuum lines (28 into N75, 2-22 in VCDS n75 output test, confirmed actuator starts moving at 3.5/4 and stops ~18ish)
- sprayed lube on actuator rod, exercised vnt mechanism a bit, couldn't find anything sticking or catching
- checked and found snow screen was already gone
- cleaned MAF, discovered it was the original failure prone Bosch model (not revision C)--it was a used replacement my mechanic had on hand
- intake should be clean as it was done about 10k ago, along with air filter as well
Should I:
- leave it alone, forget about it and enjoy driving it? [It is difficult for me to do VCDS logs except late at night here in Los Angeles].
- lengthen the actuator rod? (Kerma recommends I try this, if I do anything)
- replace my MAF with rev. C just in case?
- something else to check or tweak?
