Old September 15th, 2012, 03:21   #1
arne487
arne487's Avatar
Fuel Economy: 62.4 max, 53 avg
Default Preventative VanGogh for Big Power?
Seeing as the "block fix" is stronger than stock, would there be any benefit to putting one on as a preventative measure? I think some of us with big power are probably more likely to break the mounting tab off, right? Is the timing system at risk if the tab fails, or is it just the inconvenience of not being able to drive it until it's fixed? $50 to prevent wiping out a performance built head seems worth it to me.
http://www.dieselgeek.com/Broken_VW_.../vg-mk4alh.htm
His: '03 Golf - RyanP GTB2260VK, Other Fun Stuff
2004 Passat Wagon 1.8T 4-Motion 5-Speed
Hers: '10 TDI Cup Jetta - Just a skid plate and a Frostheater. She won't let me touch it.
arne487 is offline   Reply With Quote
Old September 15th, 2012, 09:15   #2
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
It definitely won't hurt, but the block only breaks there if the 3 bolts aren't tightened correctly.. I don't see any of the high hp 1.8T guys don't breaking their blocks there, and they have the same setup as far as the mounts go. Some of those guys are making stupid power too..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old September 15th, 2012, 09:20   #3
ryanp
ryanp's Avatar
i've only seena handful like this and re-used bolts that are over or under tightened seem to be the cause, not of my own have failed!
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old September 16th, 2012, 07:08   #4
ducesrwld
TDI(s): none
i was close to doing some serious damage on my motor but it was due to my procrastination on upgrading the mounts. when the main motor mount failed it caused a domino effect and snapped every bolt off on that side of the motor. needless to say i've got this piece on their now with upgraded mounts. if you do things right i don't see a need for this, if i would have just upgraded the mounts in the 1st place would never have happened.
2006 Black Jetta TDI - 5 speed bought with 17,000 miles....constant work in progress. Whitbread Sleeper Package....one of the quicker BRMs on the block
ducesrwld is offline   Reply With Quote
Old September 18th, 2012, 07:20   #5
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
I don't think the VG for the '03 will bolt up unless the block is already broken.
runonbeer is offline   Reply With Quote
Old September 18th, 2012, 07:30   #6
arne487
arne487's Avatar
That's ok. My block is from a fork truck. Doesn't sound like it's really necessary anyway.
VanGogh, Easy install? Gluhkerze TDI 101 2 December 10th, 2011 11:46
Big power! PoloPower TDI Power Enhancements 4 October 4th, 2010 11:49
Dieselgeek VanGogh bracket for broken BRM engine blocks corrado tdi Vendor & GroupBuy items for sale 2 May 29th, 2010 07:04
Big Power restrictions adr TDI Power Enhancements 12 March 16th, 2010 14:10
Big power! help importam TDI Power Enhancements 23 February 16th, 2009 01:17
Page generated in 0.15132 seconds with 11 queries
[Output: 77.34 Kb. compressed to 67.75 Kb. by saving 9.59 Kb. (12.40%)]
