majesty78 said:
170hp engine is a 16v cylinder head, so the turbo with integrated manifold wont fit to your 8v engine. Also the whole turbo construction from vc turbo is different to the vb unit. (different turbo generation).
The turbine from vb has 37.6mm exducer.
I would not recommend to use bigger than 52mm compressor with stock vb turbine. Its senseless, like has been stated already because of restriction of turbine.
Greets, Alex
Hi!!
Well the manifold are different, we can see both below:
Well I think that the big difference is the hotside, turbine. because the compressor will be hybrided to a 52mm wheel no problem there.
I 'm really trying to get a good low end boost, with some like 1.9/2.0 bar between the 2800rpm and 3800.
My hardware are now:
Ibiza 1.9 PD 130
1749VB
IC FMIC Cupra, with 60mm aluminum tubes.
BMC CDA.
Sachs racing clutch
60 mm exhaust line only with end muffler.
EGR OFF
Oil Rad.
Repro by VC power.
I have some like 195 hp @ 4000 rpm and 415 Nm@ 2600 rpm, smoke free.
the car is running good, but I whant more torque and some more hp.
Now about the 1749VC, it is possible to swap all the hotside of the VC to the VB manifold?
Or soldering the VB manifold to the VC turbine?
Should I have some gains? which are the alternatives?
Cya tks.
