Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old March 18th, 2017, 15:35   #1
buyingconstant7
buyingconstant7's Avatar
Fuel Economy: 5.7l/100km(winter) 5.0l/100km(summer)
Default When to do coolant flush?
Looked at the service manual and I couldn't find anything on when to do a coolant flush on the mk6 TDI's. My car has 80,000kms on it now, so I have no clue when I should do it. This pink coolant does last a long time, I know, since my sisters 2006 BRM lasted on it's original coolant for 10 years and 300,000km and pH was fine, colour was still bright pink. But I don't wanna push it. Any advice?
buyingconstant7 is offline   Reply With Quote
Old March 18th, 2017, 16:46   #2
turbobrick240
turbobrick240's Avatar
If it looks good, I'd change it out at the timing belt interval.
Old March 18th, 2017, 17:10   #3
How about never? You'll lose about half the coolant when you change the water pump, replace that and you'll be fine.
2002 Jetta wagon, 358K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 255K; 2011 335d, 55K; 2015 Golf Sportwagen, 5K. Principal, http://www.idparts.com
Old March 25th, 2017, 05:36   #4
dandywriter
Timing belt change is also a good opportunity to replace the thermostat.
2006 Jetta TDI 5-sp, Bosal hitch, frostheater, evo skidplate, upgraded rear springs and front spring dist kit (1" lift), GIAC Stg 1 tune, USA Spec iPod adapter, SMF clutch, Coolant Heater Grill Outlet, winter front, LED backup and lic lights, VCDS
dandywriter is offline   Reply With Quote
Coolant Flush AKAvant TDI 101 20 June 21st, 2016 20:12
Coolant Flush joshuare VW MKIII-A3/B4 TDIs 3 August 20th, 2010 09:27
How to flush coolant? ocelot VW MKIII-A3/B4 TDIs 2 April 6th, 2009 14:48
Coolant Flush jaca TDI 101 7 June 12th, 2006 07:07
Coolant Flush Shamrockez VW MKIV-A4 TDIs (VE and PD) 26 February 4th, 2006 11:01
Page generated in 0.11265 seconds with 11 queries
[Output: 63.07 Kb. compressed to 56.36 Kb. by saving 6.71 Kb. (10.64%)]
