Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old March 18th, 2017, 11:44   #1
Jlo
Default 1-2 gear yanking/pulling???
What's up gang,
So today I noticed my TDI yanks/pulls (almost as if the car is going to stall) whenever I shift from 1-2 gear. After that, all other gears are fine. There's no grinding noise when shifting or any weird sounds when doing so. I'm not sure if I'm describing this accurately, but it's not normal. Some of the recent maintenance I've done consist of adjusting the parking brake cables only. Also, I think is due for an oil change and tune up. However, I wouldn't think that could cause those issues.
What do you guys think?
Jlo is offline   Reply With Quote
Old March 18th, 2017, 12:29   #2
igiveup
If it's an Automatic transmission, you may have some issues with your valve body. There are these rubber expansion plugs that absorb some of the oil pressure between gear changes. If they are damaged it could cause a hard shift between certain gears. I'm not really an expert, but this may be a potential issue.
igiveup is offline   Reply With Quote
Old March 18th, 2017, 13:01   #3
Jlo
No, it's a manual transmission. However thanks for sharing, this might be helpful to someone with a similar problem and automatic transmission.
Old March 19th, 2017, 13:04   #4
scottw99
Sounds shifting related. Watch the RPMs when you get into second is there a spike up or down? You could be releasing the clutch too slow or too fast and without enough gas to make a smooth transition.
scottw99 is offline   Reply With Quote
Old March 19th, 2017, 18:41   #5
flee
Fuel Economy: 40-ish
Try posting in the MkIV section for more responses.
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is offline   Reply With Quote
Inner CV Joint Swap. Possible without yanking axles? rudall42 TDI 101 17 January 31st, 2013 07:58
pulling the cam gear Berniem TDI 101 6 November 16th, 2010 04:54
Where did my first and reverse gear go? A transmition pulling story. GotEuroCorrado TDI Power Enhancements 11 February 12th, 2008 21:49
Remote touching chin-- yanking my chain? treedweller General VW Discussion 9 August 2nd, 2004 19:02
Is the dealer yanking me around? classen General VW Discussion 13 May 26th, 2003 07:14
Page generated in 0.12339 seconds with 11 queries
[Output: 66.44 Kb. compressed to 58.81 Kb. by saving 7.64 Kb. (11.49%)]
