Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old March 17th, 2017, 12:40   #1
scottw99
Default Alternator + Alt Pulley Tools
Anyone have the metalnerd alternator tools required for the pulley job that they wouldn't mind lending?
Found my tensioner strut pretty beat up and loose and shaking. Going to check the alt pulley but it sounds like I'll need tensioner+idler+alternator pulley to fix it up good.
scottw99 is offline   Reply With Quote
Old March 17th, 2017, 18:09   #2
steve6
I know princess has a universal kit.. I dont own it, just thought about it.
https://www.princessauto.com/en/deta...et/A-p8466658e
steve6 is offline   Reply With Quote
Old March 19th, 2017, 01:14   #3
2ManyKMfor1Tank
TDI(s): 2000 Jetta
I have the set, up north of you a good 40 minutes, but send me a pm if you don't mind the drive. I also suggest soaring on a creeping lubricant in the meantime, mine was a real bugger to break loose.
2000 Jetta TDI - Ventectomy, Defender Skid Plate, Bilstein TC Comforts, Audi TT bushings, Newsouth Boost gauge, Recaro GLI's, Frost Heater, FK Depo headlights with HID's, PP502's, DG Racepipe, Malone Stage 3, ScanGauge II.
2ManyKMfor1Tank is offline   Reply With Quote
Old March 19th, 2017, 12:58   #4
scottw99
Thanks 2Many I'll let you know. Going to inspect the alt pulley and if it needs to be replaced with the tensioner I'll make the trip up to borrow the tool.
Old March 23rd, 2017, 09:51   #5
craig01b
craig01b's Avatar
TDI(s): None
They are usually miserably tight. I have the pa set close to Guelph.
All retired, bought a Subaru.... all wheel drive, and a little bigger than the high line. Time will tell!
craig01b is offline   Reply With Quote
Old March 23rd, 2017, 10:38   #6
scottw99
Just picked up a PA set myself, thanks guys.
Old March 23rd, 2017, 10:39   #7
scottw99
Guess I better start tearing it down then, just waiting on the parts from Canada post later today.
Old March 23rd, 2017, 10:43   #8
steve6
Scott, pretty sure im the one who replied to you on fb, but check this out thread for tips if its tight
http://forums.tdiclub.com/showthread.php?t=234251
Old March 23rd, 2017, 19:25   #9
scottw99
It came off fine, although I did take the alternator out of the car. Unless you modify the PA bit then you can't do it with that kit at least while the alt is still hooked up. Wasn't too bad, just some figuring and fiddling with the alt for the first time I took it off.
Old March 24th, 2017, 07:46   #10
steve6
Ya you have to shorten it.
Old March 26th, 2017, 17:25   #11
scottw99
Yeah saw the guide, I was in a bit of a rush to do it that day before a road trip and wasn't well equipped to modify it. It went pretty smoothly after I figured out how to wiggle the alt out.
Thanks for the help.
Old April 2nd, 2017, 00:43   #12
2ManyKMfor1Tank
TDI(s): 2000 Jetta
Sorry dude, I didn't get the pm till 2 days ago. Usually have it set to get an email, but it didn't come, sorry about that.
Old April 2nd, 2017, 11:31   #13
scottw99
No worries! Got it done and added another tool kit to the collection.
Metalnerd Alt. Pulley Removal tool + NEW Alternator Pulley N519AT Private TDI Items for Sale/Wanted 5 November 8th, 2012 16:35
Alt pulley tools ?? TDISD VW MKIV-A4 TDIs (VE and PD) 3 April 29th, 2012 20:20
Alternator pulley forsale-includes free rent of alt tools coalminer16 Private TDI Items for Sale/Wanted 7 October 29th, 2010 05:12
Alt Pulley and Metal Nerd Tools 2003 TDI Wag sucko Private TDI Items for Sale/Wanted 4 October 7th, 2010 05:01
Alt pulley tools dieseltdi South Central Regional States 0 November 6th, 2009 18:31
Page generated in 0.16069 seconds with 11 queries
[Output: 109.95 Kb. compressed to 92.09 Kb. by saving 17.86 Kb. (16.25%)]
