Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old March 16th, 2017, 12:49   #1
Mertz.2008
Default Radiator/ lower hose o-ring?
Hello my name is John, I am new to this forum thank you for having me I have a 1996 Passat B4 TDI. I am currently replacing the AC condenser and radiator a couple years ago I took it apart and I had ordered o- ring which I believe was for the lower hose Outlet. Unfortunately I do not have the OEM part number for the O-ring. My Bentley book does not show one being there, but I believe that's where it belongs. It is the correct circumference. I really have no way of knowing, I was hoping someone may know? Any help would be appreciated thank you very much!
Mertz.2008 is offline   Reply With Quote
Old March 16th, 2017, 13:01   #2
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
1H0121687A
http://www.jimellisvwparts.com/showA...roduct=5182995
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old March 20th, 2017, 20:35   #3
Mertz.2008
Thank you for the parts diagram. I wasn't able to find some of those and other parts websites. I believe there is an O-ring there.
Old March 26th, 2017, 11:33   #4
Mertz.2008
Once again I'm stumped I'm trying to put the AC condenser shroud to the radiator it appears that maybe I'm missing some spacers between the Shroud in the radiator. And once again I cannot find any illustration on any website or book that I own that shows the Shroud assembly to the condenser.Any illustrations would be greatly appreciated thank you
Lower radiator hose VE1.9 VW MKIV-A4 TDIs (VE and PD) 1 June 18th, 2013 23:41
lower radiator hose Dana B TDI 101 0 October 4th, 2012 07:09
Help: Need lower radiator hose benchote13 Ontario 4 May 23rd, 2011 18:39
Lower radiator hose, clip to radiator fan assembly VT_hawkeye VW MKIV-A4 TDIs (VE and PD) 1 June 20th, 2010 14:07
Lubricant for the lower hose O-ring? NextExit VW MKIII-A3/B4 TDIs 2 August 5th, 2008 18:47
Page generated in 0.11232 seconds with 11 queries
[Output: 61.71 Kb. compressed to 55.23 Kb. by saving 6.47 Kb. (10.49%)]
