Old March 15th, 2017, 09:10   #1
Lock_t
Fuel Economy: mid 40s
Default Motor mounts
Looking to get a dog bone and possibly motor mounts, wondering if there's any recommendations where to get them and hardware without paying an arm and a leg. Was looking into febi mounts but let's hear whats good
Lock_t is offline   Reply With Quote
Old March 15th, 2017, 10:41   #2
AnotherPerson
TDI(s): 1999 Beetle
Mounts aren't that big a deal what brand you go with if yours are shot. Bolts, for the most part it's dealing with the dealer. Some of the vendors have them but your looking same price.
AnotherPerson is offline   Reply With Quote
Old March 15th, 2017, 11:10   #3
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Here's a list of vendors (work in progress) if you need that info=
www.dieselgeek.com
www.cascadegerman.com
www.idparts.com
www.metalmanparts.com
http://www.metalnerd.com/ (tools)
VW Dealership parts-
www.WorldImpex.com
www.1stvwparts.com
www.expressoemparts.com/
www.jimellisvwparts.com/
and more at
http://www.tdiclub.com/links/tdivendors.html
Old March 15th, 2017, 11:26   #4
Dieselmonkey02
TDI(s): 02 jetta
Fuel Economy: 48-50 avg. 44 lowest 51.5 highest
Partsgeek.com, some decent prices.
ECS tuning; they carry a rebuild kit for the dog bone mount. It may be too stiff for your liking though. But it's about half the price of a new one.
Dieselmonkey02 is offline   Reply With Quote
Old March 15th, 2017, 13:01   #5
hey_allen
I bought a set of OE bushings for the big end of the dog bone mount from Black Forrest Industries for about $8.
I'm guessing that they were refitting OEM mounts with urethane bushings for sport applications and these are the left-over removed bushings.
hey_allen is offline   Reply With Quote
Old March 15th, 2017, 14:27   #6
Lock_t
Thanks for the links and info, does anyone have the thread pitch specs on the bolts for mounts or dogbone? On BFI i found this: (doesn't include thread pitch)
N-905-970-05 10x70mm bolt (qty 1)
N-102-683-04 8x45mm bolts (qty 2)
N-102-466-10 10x30mm bolt (qty 1)
Hey_Allen are these the bushings you were talking about?
http://store.blackforestindustries.com/mk4oedore.html
Is this a viable option or replacing the whole thing better, thoughts?
Old March 15th, 2017, 15:46   #7
hey_allen
That looks like the ones that I bought, though I could have sworn that they were cheaper. Still cheaper than a whole set though.
From what I'd read here, and my experience with mine, the small bushings are very slow to wear, the large end is what takes the brunt of the wear and tear on the dog bone mount.
If you have a vise to clamp the mount in, just secure it, spin out the two bolts holding the old bushings, and replace with the new ones. Cleaning up the grimy mount is an option while you have it apart.
Make sure to keep the order and orientation of the bushings as you R&R them, but not a difficult task. I did it while I was changing the oil in my engine and transmission, replaced the bushings while letting the pans drain.
Old March 15th, 2017, 18:32   #8
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
M8x1.25 and m10x1.5... IDPARTS has a good alternative Dog bone and has bolts too. Use an impact to remove them if you can, the quick snap will hopefully break them loose. I used and a ratchet on my first one and snapped the first bolt. Used an impact on the next 2 and they came right out.
Stella (Mine now): 2005 Shadow Blue Jetta Wagon TDI 09A
Mods: RC1. VCDS HEX-CAN USB (near Toledo, OH)
JDSwan87 is offline   Reply With Quote
Old March 15th, 2017, 21:01   #9
Wilkins
Fuel Economy: 4.6/5.6 - 5.3/6.7
I replaced Dogbone mount on my 2005 and was unhappy with the non OEM stiffness in cold weather. I ended up using the big end mount from an aftermarket Dogbone and the rest is my original with the original big end bushing. The original big end mount was destroyed when I tried to remove it, not unusual if it has seen lots of salt. Using a small 3/8 ratchet the bolts sheared like butter inside the mount. Galvanic corrosion between the aluminum and steel eats the steel and causes the bolts to seize inside the mount. Once the mount was off I could almost remove the rest of the bolts with my fingers.
For some reason I never could figure out the new long piece of the Dogbone would not work with the OEM bushing. The engine sat in the wrong orientation and I had to reef on it to get the vertical bolt in. I had the Dogbone apart and back together in every orientation I could think of then when I went back to the original long end it went in like it was made to first time.
That said if you have cold weather to deal with I would seriously consider the OEM rubber from BFI in your existing Dogbone. Get a cheap aftermarket unit as well so you have options and parts to combine in case you shear the bolts. If the bolts shear the only thing you can do is cut it apart.
2005 Jetta Wagon: Evo skid plate, Kerma Tune, Moog VR6 front springs, Koni Reds, Jeff's HID's, Upgraded door switches!. MKVI: Containflo+Pureflo, Rear Tiggy springs and B6 Billies, Xenon w LED, AFS, 087T BCM
Wilkins is offline   Reply With Quote
Old March 16th, 2017, 08:27   #10
Lock_t
you're talking about these from idparts?
http://www.idparts.com/dogbone-mount...a4-p-1078.html
good tip, thank you, im hoping i dont have to deal with that but never know with these things..prep for the worst.
Old March 16th, 2017, 08:35   #11
Lock_t
i do deal with cold and snow, ive read less than impressed reviews on poly bushings so ive been planning on using oem rubber ones. not sure whos idea it was to put steel and aluminum together but had my calipers strip out cause of that. but yea im thinking just getting a whole new dogbone may save a bit of frustration. thanks for the info! :thumbup:
Old March 16th, 2017, 08:41   #12
Lock_t
anybody opposed to the idea of just getting some US grade 8 spec bolts instead of the oem mount ones? curious if there would be a difference or reason not to
10x1.5 70mm bolt
8x1.25 45mm bolts
10x1.5 30mm bolt
Old March 16th, 2017, 22:28   #13
joncfinney
How do you know when the engine mounts need replacing/ is there some sort of interval? symptoms?
03 tdi
joncfinney is offline   Reply With Quote
Old March 17th, 2017, 07:18   #14
Lock_t
Generally if the motor has a lot of shake, ive read/seen that you can pull the ebrake, put it in 1st slowly let the clutch out like halfway and the push it in and if theres a lot of motor movement they're no good.
Old March 17th, 2017, 07:47   #15
BobnOH
not-a-mechanic
10x1.5 70mm bolt
8x1.25 45mm bolts
10x1.5 30mm bolt
Not me.
Keep in mind that the VW bolts, if they are in fact stretch bolts, will hold better, as in won't back out as easy.
If you do use a standard SAE Grade 8, you'd use the maximum torque for those and not the odd torque sequence called for in the instructions.
To be on the safe side, most of us will recommend the stretch bolt.
Maybe one of the mechanics on here can recommend what they use.
Febi Motor Mounts vs Corteco Motor Mounts Question xFlandies TDI 101 4 December 21st, 2015 07:21
motor mounts rev600 TDI 101 1 July 24th, 2013 19:16
Motor Mounts AMiller TDI 101 5 September 22nd, 2008 22:18
Motor Mounts? wilharper2000 TDI 101 6 December 18th, 2007 18:01
where to get motor mounts? tonywong TDI 101 11 February 21st, 2007 09:24
Page generated in 0.18780 seconds with 11 queries
[Output: 127.58 Kb. compressed to 107.26 Kb. by saving 20.32 Kb. (15.93%)]
