Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old March 13th, 2017, 18:11   #1
ctennyson
TDI(s): 2010 Jetta
Default Key Fob
Hello Guys,
My key for decided to just die yesterday. Meaning it will no longer operate the doors or trunk. The red light still operates when I press the button, but to no affect.
Where can I begin to troubleshoot ?
BTW, I only have a single key.
ctennyson is offline   Reply With Quote
Old March 13th, 2017, 18:29   #2
Uberhare
Uberhare's Avatar
Fuel Economy: Depends on what I'm towing!
Start with a new battery. I've had them dead enough not to transmit much but still flash the light. I must be getting close again, I need to be within a few feet for mine to work!
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old March 14th, 2017, 06:34   #3
KiwiCanuck
Try the new battery first. If that doesn't do it, Brian at Roseland (in Nova Scotia) has new keyfobs that you can program to your car assuming you have both keys - at least - that's what worked for me - the procedure for re-programming your key-fob is in the user's manual.
Edit: Oh... just saw you have only one key... In that case I'm not sure.
KiwiCanuck is offline   Reply With Quote
Old March 14th, 2017, 07:41   #4
Vince Waldon
Vince Waldon's Avatar
New battery is a great idea. Failing that, the fastest course would be to track down someone with VCDS... they will be able to quickly re-adapt the fob to the car.
Dunno if there's any other way, actually, when you one have one fob... the non-VCDS method requires at least one working fob.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Old March 14th, 2017, 08:51   #5
steve6
You mean key :>
You can remove the door tumbler and use a screw driver to simulate the second key if you don't have a second or vcds..
steve6 is offline   Reply With Quote
Old March 14th, 2017, 10:25   #6
Vince Waldon
Originally Posted by steve6 View Post
You mean key :>
You can remove the door tumbler and use a screen driver to simulate the second key if you don't have a second or vcds..
You mean screwdriver.
That's a great idea... you just need to be able to activate locking the driver's side door, so if you pull the tumbler and use something to trip the lock module the "two key" method should work with one key.
And a screwdriver.
Pulling the tumbler is pretty simple... requires the right triple-square driver to loosen the big bolt on the edge of the door three or four turns.
Old March 14th, 2017, 11:21   #7
Strider17
TDI(s): MK4 and MK5
i have vcds and can program the key. pm me if needed
Strider17 is offline   Reply With Quote
Old March 14th, 2017, 18:31   #8
ctennyson
TDI(s): 2010 Jetta
Just replaced the battery and to no avail.
I actually have a vcds but not sure of the process, any guidance to complete that task ?
Colin
Old March 15th, 2017, 05:29   #9
steve6
I am pretty sure this is it, http://www.ross-tech.com/vag-com/car...-matching.html
Ross Tech has an article on it somewhere if not that one.
Old March 17th, 2017, 15:38   #10
dmp
should just need a resynch, different than programming (programming it will work as well).
Unsure on that model specifically but many of the newer cars: ign on, press unlock for a second or two, take the key out and try the remote (only if the key had been programmed to the car already just lost synch)
Others: push unlock button then unlock it with the key (or unlock then push button).
I'm in oakville on saturdays, PM me if you want to meet up and i'll show you how to program the remote.
dmp is offline   Reply With Quote
Key fob dead sometimes, unlock with key, fob works again DEZLBOY VW MKIV-A4 TDIs (VE and PD) 10 August 30th, 2015 17:25
deAutoKey.com//New Key FOB shell/New Programmed Key/Diesel Fuel Only Keychain + more deAutoLED.com Vendor & GroupBuy items for sale 43 April 3rd, 2013 14:52
FS: Switchblade-type Key FOB, HLO ID, HAA Key Code anglin Private TDI Items for Sale/Wanted 1 March 15th, 2013 16:33
Wanted: New key blank, key fob for '96 B4 Passat valvecrusher Private TDI Items for Sale/Wanted 0 December 16th, 2010 19:37
WTB: Key FOB or Valet Key (#HLO 1J0 959 753 F) olywafox Private TDI Items for Sale/Wanted 6 June 28th, 2007 14:32
Page generated in 0.14242 seconds with 11 queries
[Output: 95.71 Kb. compressed to 81.17 Kb. by saving 14.54 Kb. (15.19%)]
