Old March 9th, 2017, 18:58   #1
laminated
Default anything to check repair after getting exhaust flap code
just picked up the exhaust flap code,on my 13 .
anyone have an idea what we can do first ,like lube something, clean anything.
I have a vag com, and tried an output test, but get aborted for safety on the test..
thanks
P048C 00 [237] - Implausible Signal
laminated is offline   Reply With Quote
Old March 9th, 2017, 19:16   #2
jrm
Fuel Economy: 42/52
quick reply while on the clock- yes, just pull It apart and wire brush the crusty carbon off it- shoot it with some high temp lube (graphite) and your good to go. A few buried threads about this as well
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old March 10th, 2017, 06:17   #3
Skimax
Our was replaced under the extended warranty provided by VW on this part @ 32,000 miles, 3 years 3 months, no quibbling by the dealer in Barre VT
Max
Skimax is offline   Reply With Quote
Old March 10th, 2017, 06:33   #4
laminated
13;s even though they are the same valve, arent in the recall I read.
my code is not a stuck open etc, mine comes back as signal so thinking connection issue?
Old March 17th, 2017, 09:58   #5
740GLE
If the valve isn't fully opening or closing when the ECU commands it and the system isn't seeing the desired back pressure in the EGR, it'll say its a signal issue.
I'd bet dollars to donuts its sticking and if you keep driving it it will eventually stick open.
740GLE is online now   Reply With Quote
B2AAA code, emission recall and frozen exhaust flap kathysjetta VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 1 July 16th, 2015 17:36
Check Engine Light - Exhaust Flap cmeller VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 62 April 4th, 2015 09:23
2010 Jetta Exhaust Flap Repair Northernliving VW MKV-A5 Golf/Jettas 1 December 3rd, 2012 05:35
Check Engine Light - 001164 - Sensor for Exhaust Flap: Implausible Signal neosomatic VW MKV-A5 Golf/Jettas 4 September 16th, 2009 10:11
Code 19561, valve flap for intake manifold; open or short to ground. I got this check anoblefox VW MKIV-A4 TDIs (VE and PD) 5 December 5th, 2008 19:23
Page generated in 0.13101 seconds with 11 queries
[Output: 68.45 Kb. compressed to 60.28 Kb. by saving 8.17 Kb. (11.94%)]
