Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old March 1st, 2017, 16:55   #1
6DOF
6DOF's Avatar
Fuel Economy: 44MPG, 40MPG
Default Side Mirror Swap
Anyone out there have any experience on removing the side mirrors? My 2012 Jetta is being turned back on March 25th and I am thinking of swapping the side mirrors between that car and my 2013 GLI. The GLI came with loose glass in the mirror and a free solution is to swap them out.
Anyone out there ever remove the side mirrors? how hard is it. Passenger side. Thanks
6DOF is offline   Reply With Quote
Old March 9th, 2017, 03:28   #2
firekkatz
Fuel Economy: 4.7L per 100kms
I busted my passenger mirror off about 2 years ago. I got a new one off eBay and put it on myself. About a 2 hour job. YouTube: https://www.youtube.com/watch?v=QKRnK5hNcFI
Personally I'd work a little bit more carefully than those guys but hey - it's something. Have a full complement of torx bits with you as is the german tradition.
Dan
firekkatz is offline   Reply With Quote
Old March 9th, 2017, 08:28   #3
ACHTUNG TDI
I believe the GLI mirrors have a different electric plug. I was looking to replace the side vies mirrors on my 16 Jetta TSI Sport and after reading up on the replacements I determined the GLI plugs were different than non GLI mirrors. The TSI Sport has power and heated side view mirrors but not turn signal. I wanted to upgrade to mirrors with a turn signal. They are plug and play as long as you don't try to swap in a GLI mirror.
ACHTUNG TDI is offline   Reply With Quote
Old March 10th, 2017, 05:56   #4
6DOF
6DOF's Avatar
Thanks for the information, me thinks that the easiest solution is to pull the loose mirror glass off and apply some epoxy to secure it. Did the same on my old Z4 when I clipped a pokey buzzard on an old country road last year. Shattered that glass.
Old March 13th, 2017, 17:27   #5
6DOF
6DOF's Avatar
Used epoxy to bond the glass back on to the assembly. Problem solved.
Driver Side Mirror Cap & Glue for Mirror Berk Ontario 10 December 11th, 2015 07:23
right side mirror ausiegolf TDI 101 2 September 24th, 2011 17:57
Needed glass for passenger side B4 mirror (or whole mirror) almus Private TDI Items for Sale/Wanted 4 August 24th, 2010 10:31
Side Mirror? ogdigital Atlantic Canada 6 April 2nd, 2009 05:29
Side Mirror limmy General VW Discussion 0 June 3rd, 2004 07:42
Page generated in 0.34226 seconds with 11 queries
[Output: 67.57 Kb. compressed to 59.82 Kb. by saving 7.74 Kb. (11.46%)]
