Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old February 20th, 2017, 08:27   #1
FXDL
Fuel Economy: 4.4 per 100KM's
Default Fuel filter 2010 Jetta TDI
WARNING. I bought a fuel filter single hole type from auto parts store in Bradford ON. ,Davenport Auto to be exact. I believe the brand was under Davenport which I believe is a Wix boxed for them.
Well as it turned out it dropped wright off the top part of the filter housing and it was sitting in the bottom of the filter housing and therefore not doing it's job of filtering the diesel fuel and for some time. I hope no damage to the fuel system. I pray there is none. Kept old filter and I have the bill. I will drop by tomorrow and show them. Only payed 23 bucks for it so I should have known because the fit of it was not very tight at the hole and the top part plastic tube they push onto. Installed new Mann filter.
SO be Warned who's fuel filter you us.
FXDL is offline   Reply With Quote
Old February 20th, 2017, 12:38   #2
jetlagmech
TDI(s): 2010 jetta
Fuel Economy: best tank 50.6, worst 36
Are you sure its the right filter? the 2010 has 2 possible fuel filter choices. Did the auto parts store use your VIN to find the filter?
JETLAGMECH
2010 jetta, 6sp man, & tdiclub plate frame ..build date 08-09
1956 Buick Special (my dad bought it brand new)
1946 Luscombe 8E
jetlagmech is offline   Reply With Quote
Old February 20th, 2017, 16:14   #3
FXDL
It's the wright one all wright. Single hole , top. I have bought many times and also had Double check part # The hole became larger in the diesel fuel as when first on stayed somewhat. That's what I get for being cheap.
Old February 20th, 2017, 16:27   #4
FXDL
It was 23.74 all in. I guess one gets what they pay for. Cheap for cheaply made. Most likely made in China or worse.
Old February 21st, 2017, 08:22   #5
imo000
imo000's Avatar
Price has nothing to do with quality. Please post pictures so it's easier ot understand what you are trying to describe.
imo000 is offline   Reply With Quote
Old February 21st, 2017, 10:32   #6
FXDL
Changing a fuel filter. If you have changed one then you would have seen how the single hole fuel filter mounts/ slides onto the the plastic onto the bottom side of the plate that all hoses run to the top metal part. Can't take pics as the unit is together with new better filter installed. I disagree price sometimes does affect quality.
Old February 21st, 2017, 10:41   #7
FXDL
.A 2010 Jetta TDI CJAA Diesel. Look up the fuel filer say on idparts.com and the single hole fuel filter. The hole inlarged and then dropped off of the filter head plastic so no filtered fuel. The fuel also caused the seal to change its size to even larger then when new. So cheap as far as I am concerned.
Old February 21st, 2017, 17:55   #8
FXDL
As it turns out, Checked where I got the filter and the fuel filter was made in China. Like I said you get or rather I got what I paid for, cheap price and a cheap product. So price and where it is made counts. Last time cheap junk.
Old February 21st, 2017, 19:29   #9
993er
993er's Avatar
Sort of reminds me of the oil threads where the OP wants the best oil and then springs for the cheapest oil filter.
Alex
993er is offline   Reply With Quote
Old February 22nd, 2017, 12:49   #10
imo000
imo000's Avatar
Don't blame the country. They make the product as per the customer's specifications. Blame the company that sells them.
Old February 24th, 2017, 20:12   #11
FXDL
I blame both the country and the company's who buy from them as.most stuff from China is junk and it seems most company's buy from countries such as China and others because they make a bigger profit from child labour etc and so I blame both the country where made and the companys that get their products produced by them. Blame who we will.
Botched fuel filter replacement - 2010 Jetta TDI Physio13 VW MKV-A5 Golf/Jettas 9 August 17th, 2013 07:13
2010 Jetta fuel filter bleed screw pleopard TDI 101 7 May 7th, 2012 21:04
2010 TDI Fuel Filter ?'n? JDTDICUP VW MKV-A5 Golf/Jettas 8 December 19th, 2010 10:35
Fuel filter confusion on 2010 JSW TDI rickcrna1 Fuels & Lubricants 1 July 10th, 2010 11:56
best fuel filter brand 2010 TDI DRIVE2MUCH Fuels & Lubricants 7 July 9th, 2010 19:47
Page generated in 0.14715 seconds with 11 queries
[Output: 99.19 Kb. compressed to 83.40 Kb. by saving 15.79 Kb. (15.92%)]
