Old February 18th, 2017, 15:33   #1
VernK
Default First out of warranty fault, and nearly first fault since new.
So the car had it's first out of warranty failure today, the left hand temp blend door motor has met it's maker, sticking the driver side vents on bake. The tech used a borescope to confirm the fault code, and apparently the motor has separated and jammed.
Curiously, the repair manual seems to have a clear factory bodge on reassembly, telling you to shorten one of the old screws and cut off one of the old motor's mounting lugs to use a spacer "to make it easier to install"
The motor is only 44$, labour 2 hours.
Yours
Vern
VernK is offline   Reply With Quote
Battery with one bad cell - warranty or my fault? J.P. TDI 101 11 February 21st, 2013 10:01
Vcds fault code, locate where the fault is? 009571 in 2.0TDI engine Cereal OBD Scanners 1 December 14th, 2012 13:39
Error Code: Fault # 17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault P067 fuse TDI 101 1 December 21st, 2011 13:46
Near-end-of-warranty autoscan - is this fault a concern? DoctorDawg VW MKV-A5 Golf/Jettas 4 February 21st, 2010 14:01
Airbag fault, how long is this covered under warranty? ssnapier VW MKV-A5 Golf/Jettas 2 December 8th, 2009 06:12
Page generated in 0.10135 seconds with 11 queries
[Output: 47.17 Kb. compressed to 44.49 Kb. by saving 2.68 Kb. (5.68%)]
