Old February 18th, 2017, 08:30   #1
larryejoh
Default Cams installation
I removed my head on my 2012 Passat TDI due to the water pump seizing and taking out the timing belt. I can't find any information online in the correct timing between the exhaust and intake cams. I can't find any marks on the two gears.
larryejoh is offline   Reply With Quote
Old February 19th, 2017, 04:10   #2
767wrench
Fuel Economy: 37-43
Have you tried alldatadiy.com? They should have the correct procedures for you based on your vehicle
12' Passat SE TDI; Cr 170 Turbo, Stage 3.5 malone, dpf, egr, muffler delete, traction control delete button, Sachs SRE Performance clutch with DMF, KONI Sport suspension, H&R lowering springs, Fluidampr by INA engineering, mini train horns, HID 10K projector headlights with LED DRL, painted brake calipers, ID parts winter front, frost heater, 19" Enkei Raijin - GONE TO BUYBACK
767wrench is offline   Reply With Quote
Old February 19th, 2017, 09:48   #3
jrm
Fuel Economy: 42/52
Pictures please! would love to see the workings of the ckra head as its pretty much the beta to the ea288
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old February 20th, 2017, 10:27   #4
VernK
After skimming the service manual, there are no marks as such. VW relies in several special tools that lock the pulleys in position.
Yours
Vern
VernK is offline   Reply With Quote
Old February 20th, 2017, 14:17   #5
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
No need for any tool, its really easy even without.
1 camshaft must be on the horizontal and the other one has a canal that must be on vertical on the other side of cyl. head.
I'll take photos tomorrow.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old February 23rd, 2017, 08:46   #6
larryejoh
Thanks. My two cams are gear driven on the rear /drivers side of the engine instead of chains.
Old February 23rd, 2017, 16:18   #7
VernK
Well, according to the manual it's impossible without a bunch of special tools. The intake cam gear is split for anti-backlash, so the fixture clamps the two cams together so you can install them in the bearings. Dire warnings about ruining the bearings if you don't toe the line.
Yours
Vern
Old February 23rd, 2017, 16:58   #8
larryejoh
I've seen the one you are talking about on line. Mine only have two separate gears one on each cam. It doesn't have that two piece gears.
Old February 24th, 2017, 05:23   #9
larryejoh
What I can find so far the CKRA engine does not have variable valve timing.
Cheap PD cams and Good PD cams... both available at kermaTDI VailPowder Vendor & GroupBuy items for sale 15 May 29th, 2011 10:41
New Colt Cams 5.9L Cummins Big Stick Stage 3 Cams at kermaTDI VailPowder Vendor & GroupBuy items for sale 5 May 17th, 2011 11:44
Page generated in 0.14450 seconds with 11 queries
[Output: 85.58 Kb. compressed to 72.68 Kb. by saving 12.90 Kb. (15.07%)]
