Old February 9th, 2017, 18:51   #1
drsven
drsven's Avatar
Default Code P2200 - NOX sensor
Horrible timing, but I'm trying to register a 2012 Passat in California and this his will require passing emissions testing. I have an error code: P2200 NOX sensor bank 1, sensor 1.
The code has been present for about a week and will set the CEL within 100 miles or so, which is much sooner than the readiness monitors will set.
As a preventative measure, I had the 23T3 electrical connector recall performed yesterday and reset ECU but error still persists.
I've read thru pages of complaints regarding this error, but I have yet to find a "how-to" for cleaning or replacing the sensor.
The timing of all of this could not be worse. Bottom line is that I will need to register this vehicle in CA and passing a smog inspection is mandatory.
Does anyone happen to have pictures, links or tips that might help with a DIY repair?
Thanks!
drsven is offline   Reply With Quote
Anyone else have a NOX sensor go bad? R4074 VW Passat Family (NMS and B7) TDIs (2012+) 143 August 8th, 2017 04:21
Disabling the NOx sensor? physicshogon VW Passat Family (NMS and B7) TDIs (2012+) 10 June 6th, 2016 08:11
P2209 Code NOx sensor PacoTDI TDI (Diesel) Emissions 4 January 11th, 2016 14:36
P2209 Code NOx sensor PacoTDI Quebec 1 January 6th, 2016 12:07
NOX sensor Schnell TDI VW Passat Family (NMS and B7) TDIs (2012+) 4 May 26th, 2014 08:39
Page generated in 0.10815 seconds with 11 queries
[Output: 47.46 Kb. compressed to 44.72 Kb. by saving 2.74 Kb. (5.78%)]
