Old February 2nd, 2017, 04:04   #1
dak503
Default stock headlight voltage
hi, i have a 2013 passat tdi. the first thing i did when i got my rosstech cable was to up my headlight voltage to 13 volts. i also installed orsam 65w bulbs. now i am installing hids. and i was told to return my voltage to stock. i dont recall if original voltage was 12.6 v or 12.8 v. TIA for any help you can give.
dak503 is offline   Reply With Quote
Old February 3rd, 2017, 22:47   #2
767wrench
Fuel Economy: 37-43
May depend on the HID you are using but for my car they would not come on and stay on with the stock setup due to the low voltage and bulb saver feature. Even with mine set on maximum voltage sometimes after start with switch in auto mode they will go out and require the switch to be turned off and back on. I think cranking lowers the voltage too much for them momentarily
12' Passat SE TDI; Cr 170 Turbo, Stage 3.5 malone, dpf, egr, muffler delete, traction control delete button, Sachs SRE Performance clutch with DMF, KONI Sport suspension, H&R lowering springs, Fluidampr by INA engineering, mini train horns, HID 10K projector headlights with LED DRL, painted brake calipers, ID parts winter front, frost heater, 19" Enkei Raijin - GONE TO BUYBACK
767wrench is offline   Reply With Quote
Old February 4th, 2017, 09:12   #3
dak503
thanks for the reply. the hids are from deAotokey. they come BOW cancelers. and set at 13v with the bulb life extender on. the bulb terminals melted to wire connector and bulb base holder. deAutokey thinks it might be a bas ballasts. so they supplied with all new hardware for the side that was damaged. but the want me to set everything back to stock. thats why im trying to find out the stock voltage.
TIA dave
Headlight Voltage is 10.5 volts... ? bob57434 VW MKIV-A4 TDIs (VE and PD) 18 December 22nd, 2015 13:36
Voltage regulator; voltage needed and bosch quality? guillaumeber VW MKIV-A4 TDIs (VE and PD) 3 September 7th, 2013 12:33
FS: Stock Headlight switch Lukehmk4 Private TDI Items for Sale/Wanted 1 November 22nd, 2010 00:03
voltage, no voltage, wait voltage! uhh no voltage wgargan TDI 101 1 December 10th, 2009 20:42
Stock Headlight A. Meyer Upgrades (non TDI Engine related) 3 September 20th, 2005 11:37
Page generated in 0.10375 seconds with 11 queries
[Output: 58.36 Kb. compressed to 53.12 Kb. by saving 5.24 Kb. (8.97%)]
