Old February 1st, 2017, 06:12   #1
r11
Exclamation PSA: EGR cooler, P045e, P045f
Got flashing coil lights. Read the codes using the bluetooth ODB reader ($10-someting on Amazon) - P045e, P045f.
Our engines have 2 ERG valves. One is in front, attached to the intake manifold. That one is called EGR 1, aka "high pressure valve" and is fairly inexpensive ($180-ish @ indy parts dealers) and ez to remove. Mine was replaced under wty in 1st year of ownership. I'd call it "direct" impingement valve, as it takes dirty exhaust and mixes that into the intake manifold - adding controlled amt of exhaust into pressurised air supply, past turbo.
Replacing requires draining coolant, removing the intercooler and then you remove the TB and EGR valve as assembly. Not clear if intercooler could just be unbolted, decoupled from TB and suspended, w/o requiring coolant flush.
The EGR 2 is one below the turbo. They call it "erg cooler", as it is an entire assy with EGR valve built into it. This one takes cleaner exhaust, past the DPF, cools it using the engine coolant, and feeds it into low-pressure air supply before the turbo. Clearly, taking dirty exhaust and feeding that to turbo (on air-side of it) would kill it in no time flat.
More expensive and much larger labor effort to replace. Need to drain coolant, remove DPF (which requires removal of Cat, dropping of subframe).
The valve actuator electric motor has position sensor, so it knows when the valve is open/closed. Failure to open/close is what is caught by ECM and reported by flashing coil symbol. Not clear if EGR valve failure can put your car into limp mode. Mine happened about 4 times in as many days and I didn't go into limp mode. The 4th time it happened, I started getting chimes.
The EGR is actuated under low engine load, with the goal of reducing NOx. In my case, all 4 times, I was going downhill, with my foot off the accelerator.
So there you have it.
Luckily, I did buy VW Platinum extended wty. Which I wished I didnt, till this happened. This failure is covered by wty.
Dealer mech has the tools to test the valve in the shop.
r11 is offline   Reply With Quote
Old February 1st, 2017, 06:21   #2
tdiatlast
What did you pay for the warranty, and how much would the EGR2 replacement have cost?
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old February 1st, 2017, 08:25   #3
r11
I should have the car and paperwork soon, hope it will show how much they charged the insurance for, part & labor. I am hoping it will make the extended wty pay for itself with that one repair
Need some help from TDI top techs on EGR Valve 2 ( N113) Stuck closed 00119 P045F CNGVW TDI 101 1 September 12th, 2014 05:11
WTB Flex Metal hose for the EGR cooler & all 3 EGR Cooler rubber hoses tothemax Private TDI Items for Sale/Wanted 5 July 29th, 2014 07:43
2006 Jetta BRM EGR cooler leak. Removed cooler needed skglidden VW MKV-A5 Golf/Jettas 3 September 18th, 2012 14:17
PSA: ALH EGR O-ring paramedick TDI 101 1 June 30th, 2010 12:10
FS: ALH Parts (oil cooler, EGR cooler, turbo hoses) stoutguru Private TDI Items for Sale/Wanted 3 March 23rd, 2009 17:27
Page generated in 0.13110 seconds with 11 queries
[Output: 58.96 Kb. compressed to 53.58 Kb. by saving 5.38 Kb. (9.13%)]
