Old January 28th, 2017, 04:58   #1
jimbutter
Default Crossed Terminals?
2012 Passat SE NMS
I crossed the battery terminal clamps after the DSG service. Major Brain Fart! I placed the battery in the wrong way. Im going to be replacing the voltage regulator, but not sure if its the only thing Ill be replacing. The complete VCDC Scan is below. Any suggestions where I should begin first?
Thursday,26,January,2017,04:38:40:05743
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.2.0 (x64) HEX-V2 CB: 0.4334.4
Data version: 20170107 DS267.0
www.Ross-Tech.com
Chassis Type: A3 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72
77
VIN: 1VWBN7A32CC052210 Mileage: 193440km-120198miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 1100
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CKRA) Labels: 03L-906-012-CKR.clb
Part No SW: 03L 906 012 BP HW: 03L 907 309 S
Component: R4 2,0L EDC H21 7445
Revision: 71H21--- Serial number:
Coding: 001D0012042400000000
Shop #: WSC 10124 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906012BP 004009
ROD: EV_ECM20TDI01103L906012BP.rod
VCID: 73B0D51E6B344E6F201-8026
2 Faults Found:
17262 - Terminal 30
U140A 00 [175] - Open Circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 255 km/h
Coolant temperature: -40 C
Intake air temperature: -40 C
Ambient air pressure: 0 mbar
Voltage terminal 30: 9.240 V
Unlearning counter according OBD: 40
Engine control module reset status-Bit 0: 0
Engine control module reset status-Bit 8: 0
Limitation: torque: 0.0 Nm
Limitation: accelerator pedal: 0.0 Nm
Cruise Control System (CCS): status-Bit 0: 0
Accelerator pedal travel: 0.00 %
Engine torque: -500.0 Nm
Generator: load signal: 0.00 %
4629 - ECM Power Relay Load Circuit
P068A 00 [036] - Opens Too Early
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Vehicle speed: 0 km/h
Voltage terminal 30: 0.000 V
Starter control: Interlock- or P/N-signal-Bit 0: 0
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Readiness: 1 1 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 057 P HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3113
Revision: 05551213 Serial number: 00001111181800
Coding: 0000020
Shop #: WSC 09003 957 00200
VCID: 2616FC4AE4E66BC777F-8072
1 Fault Found:
18036 - Powertrain Data Bus
P1628 - 000 - Missing Message from Steering Angle Sensor
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 40
Mileage: 193445 km
Time Indication: 0
Date: 2017.01.23
Time: 13:42:36
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Coding: C54BC0F5492700FBA30C03E592190042A71000
VCID: 7DA4F3265DF0081F465-8028
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 561 907 044 H HW: 561 907 044 H
Component: Climatronic 043 0202
Revision: 00001001
Coding: 0010001002
ASAM Dataset: EV_ACClimaBHBVW411 A01001
ROD: EV_ACClimaBHBVW411_VW41.rod
VCID: 1C62DEA2A62AA117D1B-8048
1 Fault Found:
13635840 - Supply voltage
U1011 00 [008] - Voltage too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 167
Mileage: 193445 km
Date: 2017.01.23
Time: 13:34:36
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AA HW: 5K0 937 087 AA
Component: BCM PQ35 H+ 121 0164
Revision: BL121001
Coding: 6F200E1B902B08D408880001160085480071008640A0056064 8060000C70
VCID: 74B2D6026EBA495739B-8020
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 231211 05 54 0403
Coding: 22300A
5 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 5
Reset counter: 167
Mileage: 193445 km
Time Indication: 0
Date: 2017.01.23
Time: 00:04:29
Freeze Frame:
Term 15 Off
Voltage: 8.30 V
OFF
OFF
OFF
OFF
OFF
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 167
Mileage: 193445 km
Time Indication: 0
Date: 2017.01.26
Time: 09:49:24
Freeze Frame:
Term 15 On
Voltage: 8.60 V
ON
OFF
OFF
OFF
OFF
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 127
Mileage: 193445 km
Time Indication: 0
Date: 2017.01.22
Time: 00:11:42
Freeze Frame:
Term 15 On
Voltage: 11.65 V
ON
ON
OFF
OFF
OFF
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 127
Mileage: 193445 km
Time Indication: 0
Date: 2017.01.22
Time: 00:11:42
Freeze Frame:
Term 15 On
Voltage: 11.65 V
ON
ON
OFF
OFF
OFF
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 193445 km
Time Indication: 0
Date: 2017.01.23
Time: 13:33:37
Freeze Frame:
Term 15 On
Voltage: 9.45 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003ENM01AHCG
Coding: 00003548
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 6FB8D96E071C6A8FC49-803A
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y110000A5KW0-
Coding: 303044
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME512A3366ZZZT
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME46470267ZZZU
Crash sensor for side airbag: rear: driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME44131916ZZZI
Crash sensor for side airbag: rear: passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME094B1716ZZZT
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME08184F11ZZZW
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME5F254F11ZZZ0
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 167
Mileage: 193445 km
Date: 2017.01.23
Time: 13:30:23
9483264 - Seat Occupied Recognition
B10B4 00 [008] - Function Restriction due to Undervoltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 167
Mileage: 193445 km
Date: 2017.01.23
Time: 13:29:39
9483008 - Seat Occupied Recognition
B10B3 00 [008] - Function Restriction due to Implausible Message(s)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 167
Mileage: 193445 km
Date: 2017.01.23
Time: 13:29:19
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20111127200692
Coding: 088A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWSXS.rod
VCID: 76B6EC0A78465B4707F-8022
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-YVJ H06 0022
Coding: E20000
1 Fault Found:
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 561 920 970 C HW: 561 920 970 C
Component: KOMBI H07 0507
Serial number: 00000000000000
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
VCID: 1A6ED8BAAC1EDF27C37-804E
2 Faults Found:
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 127
Mileage: 193445 km
Date: 2017.01.22
Time: 00:11:40
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 08011201291022
Coding: 461000
VCID: 3D2433261D70C81F065-8068
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 127
Mileage: 193445 km
Time Indication: 0
Date: 2017.01.22
Time: 00:11:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 127
Mileage: 193445 km
Time Indication: 0
Date: 2017.01.22
Time: 00:11:38
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 167
Mileage: 193445 km
Time Indication: 0
Date: 2017.01.26
Time: 09:49:24
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0507
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8EC87A3CFE8FA7937-803E
No fault code found.
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661416020
Coding: 020000
VCID: 290CF776F9F844BF5AD-807C
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Mileage: 0 km
Time Indication: 0
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 B HW: 1K0 035 274 B
Component: RNS315-NAR H35 0265
Serial number: VWZAZ2M8491135
Coding: 0400042104000B0000008000
ASAM Dataset: EV_RNS315NARV2UDS A01004
ROD: EV_RNS315NARV2UDS.rod
VCID: 2310E55E9B549EEF101-8076
Data medium:
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V2 0002
2 Faults Found:
1048580 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 167
Mileage: 193445 km
Date: 2017.01.23
Time: 13:30:11
1048669 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 241
Mileage: 120751 km
Date: 2015.06.18
Time: 17:43:35
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0003772747
Coding: 0404F5
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BE09DBEE3A4E62F181-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Serial number: --------------------
Coding: 800000
2 Faults Found:
65793 - Supply voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 193445 km
Date: 2017.01.26
Time: 09:47:49
131584 - Motor for Rear Window Regulator
B11EE 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 127
Address 44: Steering Assist
Cannot be reached
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 01030108
VCID: 6FB8D96E079C6A8FC49-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011131802320
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0004
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0003775739
Coding: 0404F4
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CE29EA2E6AAE11711B-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 193445 km
Date: 2017.01.26
Time: 09:47:49
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 127
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661490129
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 2708F14EEF6C72CF4C9-8072
1 Fault Found:
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Mileage: 193445 km
Date: 2017.01.26
Time: 09:48:25
End----------(Elapsed Time: 01:28, VBatt start/end: 12.0V/12.2V)-----------
jimbutter is offline   Reply With Quote
Old January 28th, 2017, 21:04   #2
jrm
Fuel Economy: 42/52
have you tried running it? I did the same thing on my civic (new optima battery had reversed posts- found out what a group 51R means the hard way) lucky for me it didn't hurt a thing.
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old January 29th, 2017, 04:47   #3
nord
I believe you have no choice but to start the car (if it will start) and begin to put the codes to bed. Some may clear, some may need to be cleared, and some may remain and indicate damage to the modules they monitor.
While I can't guarantee anything, this may be an insurance matter. Damage was unintentional and not collision related. Comprehensive coverage may come into play.
As to damage it's always a crap shoot. Sometimes nothing. Other times only very minor problems. And then times when "Murphy" visits just about every component in the vehicle. Let's hope the majority of codes will clear and that damage will only be minor in nature.
nord is offline   Reply With Quote
Old January 30th, 2017, 05:00   #4
compu_85
Gadget Guy
compu_85's Avatar
2x. Clear all the faults, and see what comes back.
From a quick glance it looks like you might have blown up the steering rack and steering column computers. Those might just be fuses though. How big was the spark when you hooked it up wrong?
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old January 30th, 2017, 05:39   #5
pdq import repair
Fuel Economy: 38.5
Check all your fuse, replace the blown ones, and wipe all the codes. Drive the car and see which come back. Might want to wipe the codes once after driving to get a total reset. I would remove the cables and touch them together to discharge all computers after the first drive if there are codes still showing.
Then you can chase the ones that remain.
pdq import repair is offline   Reply With Quote
Old January 31st, 2017, 11:20   #6
Ol'Rattler
Ol'Rattler's Avatar
Check the big fuse for the alternator.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old February 2nd, 2017, 04:15   #7
740GLE
btw some sparks are normal when connecting a battery the correct way.
Looks like a lot of the faults are temporary.
Try and fire it up.
740GLE is online now   Reply With Quote
Old February 5th, 2017, 15:06   #8
jimbutter
Post
First, I'd like to thank everyone for their response. It's truly appreciated. Thank you. After charging the battery 14.2V, I was able to start her up. I cleared all the fault codes and took her for a spin for about 20 mins on the backroads and then the highway to open her up. I reached 80 mph without issue. The ERROR ESP was still active on the display. I pulled her back into the barn and ran a new VCDC Scan while she was running.
Here's what I noticed from the test drive:
1. Power Steering is out. Reminded me of a Subaru Wagon I once owned in my 20s.
2. Alternator doesn't provide a charge. Confirmed with voltmeter after test drive 12.3V.
3. Suspect ABS is also out. Different feel when depressing break peddle.
The Scan did improve. I great advice!!! Thank you! Here's what cleared:
01-Engine Cleared
08-Auto HVAC Cleared
15-Airbags Cleared
16-Steering Wheel Cleared
2E-Media Player 3 Cleared
52-Door Elect, Pass Cleared
77-Telephone Cleared
Supply Voltage and Under-Voltage errors cleared as well
My next step is to replace some of the fuses; however, I'm not sure which fuses to replace. The dealer is absolutely no help and I can't find anything online. Most are photo copies from a manual which doesn't match. Specifically, I'm concerned with any fuse associated with the:
1. Alternator
2. Power Steering Control Module (J500)
2. Steering Angle Sensor (G85)
3. Control Module for Tire Pressure Monitoring (J502)
I'm not as concerned with ABS system just yet. That's another project for another day. I'm mostly concerned with the alternator. The regulator replacement shouldn't be too much of pain, but I could be wrong??? Looks like I'll need to move a bracket containing a couple of hoses from the radiator out of my way and the interior wheel cover (couple of screws). Then the A/C compressor followed by the tensioner pulley mechanism to finally get to the alternator.
The regulators is on back order with no guaranteed ship date. I checked with the dealer to see what they'd charge. They want $1095, not including parts, to pull the alternator and check it over. I'd rather check the fuses first to see if that's the problem (fingers crossed).
Once again, I really appreciate the advice......
Here's the complete scan:
Sunday,05,February,2017,12:50:23:05743
Data version: 20170131 DS267.1
www.Ross-Tech.com
77
VIN: 1VWBN7A32CC0552210 Mileage: 193450km-120204miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
77-Telephone -- Status: OK 0000
Readiness: 0 0 0 0 1
Coding: 0000020
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 193445 km
Time Indication: 0
Date: 2017.02.05
Time: 00:04:08
Revision: 00H31001
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 128
Mileage: 193445 km
Time Indication: 0
Date: 2017.02.05
Time: 00:04:24
Freeze Frame:
Count: 3
Count: 14
Count: 20480
Count: 166
Count: 44544
Count: 0
Count: 766
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 128
Mileage: 193445 km
Time Indication: 0
Date: 2017.02.05
Time: 00:04:24
Freeze Frame:
Count: 3
Count: 14
Count: 20480
Count: 16390
Count: 44544
Count: 0
Count: 766
Count: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 128
Mileage: 193445 km
Time Indication: 0
Date: 2017.02.05
Time: 00:04:24
Freeze Frame:
Count: 3
Count: 14
Count: 20480
Count: 8213
Count: 44544
Count: 0
Count: 766
Count: 0
Revision: 00001001
Coding: 0010001002
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09clb
Revision: BL121001
Coding: 22300A
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 128
Mileage: 193445 km
Time Indication: 0
Date: 2017.02.05
Time: 00:04:47
Freeze Frame:
Term 15 On
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 128
Mileage: 193445 km
Time Indication: 0
Date: 2017.02.05
Time: 00:04:49
Freeze Frame:
Term 15 On
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
Coding: 00003548
Coding: 303044
Coding: 088A140000
Coding: E20000
Coding: 231E01
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 128
Mileage: 193445 km
Date: 2017.02.05
Time: 00:05:21
Coding: 461000
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 128
Mileage: 193445 km
Time Indication: 0
Date: 2017.02.05
Time: 00:05:39
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 128
Mileage: 193445 km
Time Indication: 0
Date: 2017.02.05
Time: 00:05:39
Serial number:
Coding: 000000
Coding: 020000
Data medium:
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 128
Mileage: 193445 km
Date: 2017.02.05
Time: 00:06:11
Coding: 0404F5
Slave Driver:
Coding: 800000
1 Fault Found:
B11EE 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 168
Mileage: 193445 km
Date: 2017.02.05
Time: 00:06:21
Cannot be reached
Coding: 01030108
Coding: 181100
Coding: 0404F4
Slave Passenger:
Coding: 800000
2 Faults Found:
66048 - Motor for Front Window Regulator
B11EC 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 128
Mileage: 193445 km
Date: 2017.02.05
Time: 00:08:26
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 168
Mileage: 193445 km
Date: 2017.02.05
Time: 00:08:26
ROD: UHVNA.rod
End----------(Elapsed Time: 01:01, VBatt start/end: 12.1V/12.1V)-----------
Fingers Crossed! gulfcoastguy VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 13 May 5th, 2013 14:07
Just crossed over to the dark side qquixotic VW Passat Family (NMS and B7) TDIs (2012+) 15 March 30th, 2013 15:16
Battery polarity crossed tdiphile TDI 101 19 December 4th, 2009 07:22
Crossed headlamps? Spine VW MKIV-A4 TDIs (VE and PD) 11 June 10th, 2003 17:36
Chipped and Crossed Karjar TDI Power Enhancements 2 March 30th, 2001 23:15
Page generated in 0.19061 seconds with 11 queries
[Output: 130.77 Kb. compressed to 115.40 Kb. by saving 15.37 Kb. (11.75%)]
