Old November 30th, 2016, 13:18   #1
Yankinwaoz
Default Dang.. water pump failure
My coolant warning light came on this morning. The reservoir was almost empty, and I could see coolant splashed around the front of the motor and puddles on the under shield.
Took it to VW dealer this morning. They called me and told me that the water pump need to be replaced. $1250 job.
But, he said that they have to remove the timing belt to get to the water pump. And since I have 108k on the motor, it is almost due for a new timing belt. So I should replace it at the same time. Doing that will bump the cost to $1450.
I decided to go ahead and do the belt and the pump. I plan to turn in my TDi. But not until after we complete our house purchase early 2017. I don't need a car payment right now, nor any dings on my credit history for inquiries.
I'm also hoping that VW will have the bugs worked out of their turn-in process by the summer of 2017. I don't feel like being their guinea pig for training.
Well. I hope nothing else fails between now and then. If I didn't have this house purchase looming over my head, I would just have ignored it and turned it in.
Yankinwaoz is offline   Reply With Quote
Old November 30th, 2016, 13:31   #2
Tdijarhead
A water pump is part of the timing belt change. The pump should be changed each time the belt is. Though I understand some dealers change just the belt. Which in my opinion borders on malpractice. Everything the belt touches that moves rollers, pump ,tensioner etc should all be included in a belt change.
Tdijarhead is offline   Reply With Quote
Old November 30th, 2016, 18:41   #3
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
I've heard of a few water pumps failing before the 130,000 mile timing belt interval. Volkswagen seems to have a problem with water pump longevity in general.
Trusted TDI Mechanics Map || TDIClub Chat
Old December 7th, 2016, 08:34   #4
IXLR8
I have 86K miles on my 12 Passat, it has a water pump leak. I also have no heat in the car, I am wondering if the deposits that block the heater core are chewing up the pump seals. Car has been sitting since March waiting for the buyback. I am certainly not paying that kind of money to get it fixed. Praying I can make the 65 mile drive to dealership, if VW Roadside assistance won't tow it in.
Jim Peck
'12 TDI Passat SE 6M, Platinum Gray w/Moonrock- 86,750 miles, 52 mpg. Buyback 12/16/16
'02 TDI Golf, 5 spd., 290K miles -PP520, RC3+ , VNT-17, Webasto, .68 5th gear.
IXLR8 is offline   Reply With Quote
Old December 7th, 2016, 10:24   #5
Lex Tdi
TDI(s): 2013 Passat
Brilliant, extend the life of the timing belt and forget to improve the water pump so that it lasts as long....
2013- Passat SE DSG 120,000 miles
RIP 2003 Jetta - 444,000 miles
SOLD 2001 Jetta - 300,000 miles
Thanks to Paramedick (Bruce) for being my local Guru for over a decade!
Lex Tdi is offline   Reply With Quote
Old December 7th, 2016, 11:25   #6
251
TDI Owner/Operator
Do most of these NMS Passat TDI's go 130K between timing belt/water pump jobs or do majority have water pump failure before 130K is reached? I'm assuming water pump failures are not that common as there don't seem to be many threads about it here unlike the NMS heater core issue as an example.
Is there a more robust aftermarket water pump out there for the 2.0 TDI? (I recall ALH water pumps originally had plastic impellers and later ones went to metal including VW OEM ones IIRC.)
I'm thinking if water pump usually fails before 130K then it may be better to do timing belt every 100K like on the ALH TDI's so it is "routine maintenance" as opposed to 'do another timing belt because water pump went' $$ repair. Just thinking out loud here as I still have many miles to go before a timing belt is needed on my Passat...
251 is offline   Reply With Quote
Old December 7th, 2016, 12:19   #7
Good Ol' Boy
VeeDubTDI's Avatar
At this point, it's hard to tell. I'd say replace the water pump when you do a timing belt, and if the pump fails or leaks prematurely, go ahead and do the timing belt at the same time. I won't worry about changing things early if there is no problem.
Old December 8th, 2016, 00:44   #8
767wrench
Fuel Economy: 37-43
Im gearing up to change my timing belt soon. I'm at 122,000. Had failed heater core but no leaks anywhere else yet
12' Passat SE TDI; Cr 170 Turbo, Stage 3.5 malone, dpf, egr, muffler delete, traction control delete button, Sachs SRE Performance clutch with DMF, KONI Sport suspension, H&R lowering springs, Fluidampr by INA engineering, mini train horns, HID 10K projector headlights with LED DRL, painted brake calipers, ID parts winter front, frost heater, 19" Enkei Raijin - GONE TO BUYBACK
767wrench is offline   Reply With Quote
Old December 10th, 2016, 05:22   #9
BarryT82
That's really expensive to change the water pump and timing belt. Find an independent shop and get it done for half the price.
BarryT82 is offline   Reply With Quote
Old December 11th, 2016, 08:13   #10
dpospres
dpospres's Avatar
Water pump failed on my 2012 Passat at 59,800 miles. Replaced under warranty and dealer replaced timing belt as well under warranty since it got antifreeze on it. Lucked out by 200 miles.
dpospres is offline   Reply With Quote
Old December 13th, 2016, 19:02   #11
hybridp
TDI(s): None
I've got a coolant leak and I can't for the life of me narrow it down to a hose. It seems to be dripping right from the biggest pulley. I imagine that's the main drive pulley? Where is the water pump and pulley in relation? I have 82k miles...the coolant will leak out in about 1-2 days and the temp gauge will start creeping. Sign of an impeding water pulley failure?
hybridp is offline   Reply With Quote
Old December 14th, 2016, 11:05   #12
Good Ol' Boy
VeeDubTDI's Avatar
I would say that you're most likely due for a water pump and timing belt job.
Old December 14th, 2016, 16:05   #13
carlrx7
47k, Coolant low light came on Saturday, topped off with distilled water thinking it was just "the cold". I drove about 40 miles since and the coolant low light came on again. I filled it up quickly as I was heading to work. On my first break I popped the hood and could smell the coolant, I looked further down and noticed the pulleys and belt are dripping in coolant and the tank is down about an inch already (10 miles to work). VW roadside assistance is on the way to pick up the car. Hoping it is all covered under warranty, assuming water pump.
My heater core is also clogged (not part of the extended warranty), I wonder if one could have caused the other?
Where is that buyback check?
UPDATE** Car is back from dealership with a new water pump and timing belt, all covered under 60k powertrain.
-Carl
carlrx7 is offline   Reply With Quote
Old January 2nd, 2017, 01:20   #14
Deepwater6
Deepwater6's Avatar
Fuel Economy: average 38-40 MPG
Thumbs down
My 2012 Passat TDI SEL also has a water pump leak with only 51k on the odometer. The sad point in was covered on the 5 yr. 60k warranty but I missed it by one month. This issue is one of many that have cost me big since the 3/36k warranty expired and have come to one conclusion. Sell your VW BEFORE the warranty expires. I have also decided to sell my well maintained Passat back to VW so I may purchase another vehicle brand that is more dependable. I advised VW that I will never buy another vehicle from them since they will not provide assistance with the water pump. Pry to owning the VW I owned a Toyota Camry V6 XLE with zero (0) problems and 81K when I said good bye. I admit it......I F'ed up buy a VW, shame on me and was sold on Clean Diesel with great MPG. The most expensive cost per mile ever. VW Sucks!
Deepwater6 is offline   Reply With Quote
Old January 2nd, 2017, 08:37   #15
redbarron55
VW dealers don't routinely replace the water pump and idlers when they do a timing belt.
Why do that when they can do each separately for more $$.
The main reason to sell a Dub is the revenue stream from the sale in the shop.
Vw counts in the revenue stream from parts sales as well.
redbarron55 is offline   Reply With Quote
Premature water pump failure diesel_lover VW MKIV-A4 TDIs (VE and PD) 1 October 13th, 2011 06:21
Water pump failure Bob Schaefer TDI 101 14 October 17th, 2008 14:21
Water Pump Failure? iamatt TDI 101 10 August 20th, 2007 10:16
Water pump failure frank_golf VW MKIV-A4 TDIs (VE and PD) 17 August 1st, 2005 02:49
water pump failure 47000 blownTDI VW MKIV-A4 TDIs (VE and PD) 22 July 25th, 2001 22:38
Page generated in 0.17715 seconds with 11 queries
[Output: 130.78 Kb. compressed to 109.82 Kb. by saving 20.96 Kb. (16.03%)]
