Old November 6th, 2016, 08:13   #1
DEAD-BROKE
DEAD-BROKE's Avatar
Default SMURFING mad
so thursday i had the 40K service done, today i go to head to the range open the trunk and find this mess... im pissed.
DEAD-BROKE is offline   Reply With Quote
Old November 6th, 2016, 11:19   #2
RebelTDI
Yuck! Clearly spilled DEF. Unfortunately, it takes a day or 2 for it to dry, leaving the telltale precipitate. Give the service manager a call and let him/her know. They should be able to get that cleaned out. I'm guessing they'll be refilling a lot less DEF in coming days
RebelTDI is offline   Reply With Quote
Old November 14th, 2016, 08:59   #3
Rico567
Clear incompetence in filling the DEF. I've now done a DEF refill twice in our Passat (after my free service expired), and spilled nary a drop. That bottle they sell at the dealer is supposedly spill-proof, but I use the M-B 10 liter jug w/ hose. The hose screws onto the filler neck in the trunk and is vented. Just set the jug on some suitable support and let it drain. When it's empty or stops draining, you're done*. Unhook and walk away. I got the M-B setup for $40 delivered on sale, and I just refill the jug with the $7 jug from Rural King, since DEF is DEF.
*It's probably wise to discard any leftover DEF, since the stuff is supposed to have a shelf life. At those prices, who cares?
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is online now   Reply With Quote
Old November 14th, 2016, 09:19   #4
jrm
Fuel Economy: 42/52
dang that sucks, iv never spilled a drop even with those 2.5 gallon wall mart totes- just tilt them right into the hole with the spout on the left for proper spout breething
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old November 14th, 2016, 09:25   #5
740GLE
The 2.5 gal jugs easily fit in the tank each time you get a warning, no need to really top it all the way up.
yet another reason to skip the dealer
740GLE is online now   Reply With Quote
Old November 14th, 2016, 12:42   #6
jetlagmech
TDI(s): 2010 jetta
Fuel Economy: best tank 50.6, worst 36
Wonder how much was spilled around the tank down into the body.....Isn't that stuff corrosive?
JETLAGMECH
2010 jetta, 6sp man, & tdiclub plate frame ..build date 08-09
1956 Buick Special (my dad bought it brand new)
1946 Luscombe 8E
jetlagmech is offline   Reply With Quote
Old November 14th, 2016, 19:22   #7
mrmoto35
I too have never spilled a drop, but the one time I let the dealer add it they spilled it. I had even told the service writer to please ask them to be careful. I let the service manager know, and I was not polite about it. F****** Donkeys...
I have never in my life had new car service any where near as bad as it has been with my NMS and 2 different dealers. My grandfather owned a few dealerships long ago but I can tell you that he made sure any car coming in for service was well taken care of. And he certainly didn't hire donkeys to do the work.
The biggest factor is flat-rate compensation. Many mechanics now are ripping through our cars as fast as possible in order to make more money. Having someone who is flat-rating your car can be bad news, especially at VW it would seem.
mrmoto35 is offline   Reply With Quote
Old December 9th, 2016, 13:28   #8
smoav8r
Fuel Economy: Prius Killer!
They spilled DEF in my trunk on every service up to and including my most recent, the 40K. My buddy, who has the same car, had a pool of the stuff down by the spare tire.
On the 30K they were at least smart enough to cover the area with shop rags before spilling it. I found those when I got home. After the 40K I saw it before I left the lot but the car is going back to VW so it will be their problem.
I'm over VW service.
smoav8r is offline   Reply With Quote
Old December 11th, 2016, 05:03   #9
wilder11354
i use the 2 liter bottle that VW has, with plunger valve set-up. i refill it with a 2.5Gal jug, then install and push down. Simple, easy, and no spills. I make sure DEF is FULL before winter, so to keep heat elements fully submersed in def.... hopefully to keep elements from burning up.
wilder11354 is offline   Reply With Quote
Old December 12th, 2016, 09:07   #10
740GLE
I didn't think it was the heater element that was burning up but a sensor that failed. Sadly the sensor is only purchased by the whole assembly.
Old February 4th, 2017, 21:00   #11
pparks1
I had them spill it once in the trunk, from there on out, I just asked them to put the jugs in the trunk and I would fill it myself when I got home.
Sadly, my 2013 Passat TDI was hit while parked by a driver who fell asleep and it was declared a total loss by insurance. This happened on 8/10/2016, so I didn't see a dollar from VW for either a fix or a buyback, as I was excluded from the settlement. My daily driver is now a 2016 Honda Accord EL-X sedan.
pparks1 is offline   Reply With Quote
Old March 7th, 2017, 14:03   #12
silvrmax04
Hot soapy water will clean it up.
________________________________
2015 Passat TDI SE DSG
2012 Passat TDI SE 6MT (ready to turn in)
2004 Duramax 2500
2002 PSD Excursion
silvrmax04 is offline   Reply With Quote
Old March 9th, 2017, 09:53   #13
740GLE
Sadly they were prob filling from a drum but charge you as if they were using the bottle. If they were just to put the jugs in the trunk why not just buy the stuff at walmart, got 2.5 gal jug for $7.50 last time I topped up.
I am going MAD...... Can anyone help fotodaddy TDI Power Enhancements 7 August 31st, 2007 19:19
ECU Gone mad Ben-Zion Petersen VW MKIV-A4 TDIs (VE and PD) 12 October 20th, 2006 17:54
Lancaster Get Together.... :mad: EightAngryValves Eastern USA 5 November 9th, 2003 06:06
:mad: TDi110 TDI 101 3 October 29th, 2001 16:46
Am I mad? Bad Karma Non VW Group Diesels 9 June 24th, 2001 17:22
Page generated in 0.15574 seconds with 11 queries
[Output: 111.24 Kb. compressed to 93.18 Kb. by saving 18.06 Kb. (16.23%)]
