Old December 16th, 2015, 10:10   #1
xFlandies
Default Febi Motor Mounts vs Corteco Motor Mounts Question
Like title says,
Is anyone running Febi Motor Mounts and how are they compared to Corteco Motor mounts ? I am trying to remove the vibration from my steering wheel and seat.
The dogbone mount I will be buying is by Lemfoerder.
I personally dont know which one to get because I have seen mixed reviews for Febi.
Thanks.
xFlandies is offline   Reply With Quote
Old December 18th, 2015, 10:05   #2
Curious Chris
Fuel Economy: 47/42/38
There is general agreement that FEBI (OEM) will give you smoothest ride. I had vibration and when I changed all mounts with FEBI it went away. Of course I have replaced every part of the suspension in my car too.
Wavetrac LSD, Bosch 230'a with RC4.5, Whitbread 2.5" downpipe, PD lift pump, South Bend Stage 2 Endurance Clutch, steel skid plate, Wingnut inspired EGR mod, MyCruiseAgent no drill EGT, MoGolf skidplate mod
Curious Chris is offline   Reply With Quote
Old December 18th, 2015, 14:33   #3
xFlandies
I am trying to get ride of the vibration and jerking when I turn the car on and also when trans is shifting, I get either a jerk or a pause (no gear is not refusing to go in).
Here is the febi mount: https://order.germanparts.ca/product...pe=APPLICATION
I just dont want to buy this mount and the other ones too and a worse vibration
Old December 20th, 2015, 04:03   #4
Rembrant
Rembrant's Avatar
Fuel Economy: 50 MPG.
I replaced all three mounts last winter...both engine and trans mounts were Febi, but I'm not sure what brand the dogbone was...it was just a Worldpac replacement IIRC...nothing special.
I am having zero issues with vibration or shifting gears or anything while driving the car....everything is fine in that sense. However, the one thing that seems to have developed is that it feels like the engine "jumps" or "jerks" when I start it. I know it wasn't like this when all of the mounts were new...it did develop later on.
I'm not sure which mount in particular is loose enough to cause this jump/jerk feeling, but I assumed it was the dogbone....because the engine wants to rotate when it starts? I've been meaning to get somebody else to start the car while I watch under the hood, but I just haven't gotten around to it yet.
Rem
2006 White Jetta BRM TDI 5spd w/Black Leather.
2011 Black Lexus IS250 AWD. My wife's, the high roller.
1984 Ford F150 Stepside project. Old school 3 on the tree.
Rembrant is offline   Reply With Quote
Old December 21st, 2015, 08:21   #5
Curious Chris
The parts are cheaper at IDparts: dogbone $25.95 and the motor and transmission are $59.95 each. http://www.idparts.com/transmission-mount-a4-p-459.html
Motor Mounts geardriven TDI Conversions 6 April 26th, 2014 12:44
motor mounts rev600 TDI 101 1 July 24th, 2013 20:16
Question about motor mounts Judson VW MKIV-A4 TDIs (VE and PD) 6 February 19th, 2013 09:32
Motor Mounts shih00 South Eastern USA 2 October 3rd, 2005 15:00
Motor mounts EHB VW MKIV-A4 TDIs (VE and PD) 4 July 26th, 2004 20:18
Page generated in 0.09171 seconds with 11 queries
[Output: 69.57 Kb. compressed to 61.64 Kb. by saving 7.93 Kb. (11.40%)]
