Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old October 13th, 2015, 17:14   #1
wwwabbit
TDI(s): 2011 Jetta
Default P13D7 / P13D9 Glow Plug in Hole 4.
I got the P13D7 / P13D9 codes coming up and a check engine light on. Searching around abit and it seems fairly common. I am going to swap 3 and 4 just to make sure it follows the plug.
Any tips for doing it? I think someone said a 12mm socket.
Should I use any high temp ant-seize or will that mess up the grounding on it?
Thanks!
wwwabbit is offline   Reply With Quote
Old October 13th, 2015, 17:42   #2
JSWTDI09
JSWTDI09's Avatar
Beru (the Glow Plug manufacturer) does not recommend any anti-sieze compound of any kind. I believe that a 12mm deep socket works. The most important thing is not to over torque the GPs. I would look it up, but if i recall correctly, it is only something like 11 or 12 ft-lbs of torque to install the GPs. You do not want to break them while installing them.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old October 13th, 2015, 22:14   #3
wwwabbit
TDI(s): 2011 Jetta
Glad you reminded me about torque specs. I found a few sites, and a friend has alldatadiy, both show 12nM, which converted is 8.8 ft-lbs. So be very light on them is what I am getting. Going to dive in tomorrow after work and see what happens.
Old October 13th, 2015, 23:17   #4
JSWTDI09
JSWTDI09's Avatar
12nM vs. 12 ft-lbs - yep, that's the kind of mistake I could make. That's why I recommended looking it up.
Have Fun!
Don
Old October 20th, 2015, 20:10   #5
wwwabbit
TDI(s): 2011 Jetta
Swapped the plugs from 3 and 4 to confirm it was the plug, error moved to plug 3. Ordered a new plug. It is harder to get the wire out of the way than it is do the rest of the job. I guess it could have killed VW to add another inch to the wire so you didn't have to float the hole harness.
Man these little plugs are not cheap!
Old March 16th, 2017, 10:58   #6
pikawel
I'm sorry for resurrecting this thread but I am receiving the exact same codes. What glow plug do I need to buy? I see there's a giant price disparity between the ones with sensors and the ones without. I just need the MIL off so I can get the thing through emissions!
Any response is greatly appreciated.
Current: 2012 Grey Passat - DSG (Bought at 82k)
Retired:
2012 Grey Passat - DSG (61k to buyback @ 73k), 2013 White JSW - DSG (20k to crash @ 60k), 2006 White Jetta - DSG (32k to 154k), 2000 Black Jetta - Auto (107k to 170k)
pikawel is offline   Reply With Quote
Old March 17th, 2017, 09:30   #7
meerschm
meerschm's Avatar
not sure which car.
you can check with one of the vendors here.
but they will want to know at least the model, and hopefully the VIN to verify correct fit.
Mike
Free advice: it is worth what you pay for it. (sometimes)
meerschm is offline   Reply With Quote
Old March 25th, 2017, 20:55   #8
wwwabbit
TDI(s): 2011 Jetta
Confirm with your local parts place, but mine had the sensors in it (hence the code.) Not a cheap little glow plug, might be worth moving it to another cyl. to confirm that is the issue.
Glow plug broke in half in the hole on my A4 Joester TDI 101 39 November 17th, 2015 08:26
CEL code P13D7 and P13D9 splash07s VW MKV-A5 Golf/Jettas 5 July 30th, 2015 07:46
Glow plug hole #4 cross-threaded need opinion mkluk TDI 101 7 January 20th, 2009 23:02
Glow plug hole ruined Herm TDI VW MKIV-A4 TDIs (VE and PD) 3 October 25th, 2008 09:38
Crossthreaded Glow Plug hole mogly VW MKIII-A3/B4 TDIs 6 November 26th, 2005 09:40
Page generated in 0.10254 seconds with 11 queries
[Output: 84.51 Kb. compressed to 72.71 Kb. by saving 11.80 Kb. (13.96%)]
