Old May 23rd, 2015, 14:34   #46
skinnyb
TDI(s): 2013 JSW TDI
Fuel Economy: Slightly north of 40 MPG
The parts for mine came in and I had mine repaired today. The Fidelity Platinum warranty paid to replace the entire heater assembly and refill the fluid. Out the door for the $100 deductible. I usually don't get extended warranties but I am glad I did on this one so far.
2015 Passat 1.8T Limited Edition
2013 JSW TDI DSG Malone 2.0 Eco, Tint, Wheels, Etc...
skinnyb is offline   Reply With Quote
Old May 26th, 2015, 21:26   #47
ZootsAlures
Has anybody sought out Federal Emissions Standards to be financially liable since (I believe) the Adblue system is covered by the 100k Fed. Emissions Statute?
2012 Passat TDI SE. 6SpM
ZootsAlures is offline   Reply With Quote
Old May 27th, 2015, 09:45   #48
shegel
Fuel Economy: 52
I just read the entire thread. A large portion of reported failures came from cars reported to have used PEAK DEF fluid. At first I was thinking maybe it was coincidence but now... not so much.
I'm keeping an eye on this thread as I just bought a 15' SE 6mt last friday.
1999.5 tdi, 1969 Karmann ghia, 2001 S10 crewcab, 2015 Passat SE 6mt, 1977 Goldwing
shegel is offline   Reply With Quote
Old May 27th, 2015, 09:49   #49
kydsid
TDI(s): 2012 Passat
DEF is defined by an ISO standard that is followed by every manufacturer. Peak brand def is the most prolific def available at the retail packaged level. I wouldnt subscribe the use of the easiest to obtain brand as a culprit in failures.
504/507 Oil retail source list - http://forums.tdiclub.com/showthread.php?t=360912
kydsid is offline   Reply With Quote
Old May 28th, 2015, 08:46   #50
phlfly
Banned
TDI(s): Passat SEL
Heater is not moving part so what could be a difference in fluid for none moving components. Unless, Peak has some kind oxidizer that can effect electrical components.
phlfly is offline   Reply With Quote
Old May 28th, 2015, 11:44   #51
ZootsAlures
When and if I get my car back I'll share the post mortem
Old May 28th, 2015, 14:36   #52
ZootsAlures
Nobody at VW knows how long it will take for the German sourced part be ready for shipment. I've already gone on Twitter to start quantifying how big of a problem this is- On Twitter go to: @VW and use hashtag #VWFixMyTDIAdblueSystem
Old May 29th, 2015, 05:03   #53
ZootsAlures
On Twitter- get hold of VW via #VWCares
Old May 29th, 2015, 11:04   #54
compu_85
Gadget Guy
compu_85's Avatar
Hmm, I have used Peak DEF in our car. It meets the SAE spec supposedly, and if there were any issues with it I would think the car would throw other faults.
-J
Present:
2013 Fiat 500e. 18,000 miles. Almost 100 miles per charge!
Past:
Old May 29th, 2015, 21:15   #55
Softrockrenegade
Softrockrenegade's Avatar
I only used vw adblue and have a failed heater element.
Softrockrenegade is offline   Reply With Quote
Old June 3rd, 2015, 10:45   #56
ZootsAlures
UPDATE: Got hold of VW North America's Customer Service- Advocate Group last week and a follow up this past Monday. I off loaded to this person for at least seven minutes regarding VW's failure to: Plan, forecast, deliver, and accurately communicate effectively to their own dealerships. Coincidentally, a Heater Element had arrived at my dealer's service/parts department right as I received the call. As soon as I completed the call with VW NA, I called the Service Manager who was pleasantly surprised to actually confirm that it had arrived. He had zero notification or communications from any source at VW letting him know it was headed his way.
I'm hoping that my car is completed PDQ!
Old June 3rd, 2015, 12:09   #57
cattlerepairman
cattlerepairman's Avatar
Fuel Economy: 8.4 l/100 km at 60/40 hwy/city
I realize this is for Passats and I have a 2012 T'reg with a failed tank heater, but the principle applies.
I am "just" out of warranty. Opened a case with VWoA and they agreed to cover 1/3 of the total cost for part and labour. My share is about $550, they pay $ 208.
I am on the hook for hotel and rental car (due to distance to dealership) after they messed up the parts order and "overnight" turned into two days.
If you are out of warranty, seriously think about purchasing the repair kit and having it done elsewhere, at a lower labour rate.
2012 Touareg TDI Lux, Campanella white
1974 AM General M35A2C w/w (for the 6x6 moments in life)
1999 New Beetle TDI, 1999, dark blue ("Batik Blue"), 5spd (SOLD)
cattlerepairman is offline   Reply With Quote
Old June 3rd, 2015, 16:46   #58
Sprocket
Sprockette's hubby
Sprocket's Avatar
Originally Posted by Sprocket View Post
I just replaced mine too this past Monday night on my 2010 Touareg. Kind of a pain to get to with the Touareg as the rear exhaust system / muffler needs to be dropped. I was pretty surprised at just how much the muffler weighs! Once that's out of the way it's easy peasy.
I was getting codes related to the reductant level sensor.
The only thing I noticed comparing the old unit with the new unit is that there is insulation on the wires leading to the heater element. The original unit's wires were unshielded from the heater & approx 2" up.
The heater repair kit part was $323.00 from 1st VW Parts
So far so good.
So, everything was good for a couple of weeks and now I'm getting the code below. I haven't had a chance to really research or dig into it yet.
1 Fault Found:
008430 - SCR NOx Catalyst Bank 1
P20EE - 001 - Efficiency too Low - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 169561 km
Time Indication: 0
Date: 2015.05.07
Time: 18:05:04
Freeze Frame:
RPM: 2184 /min
Speed: 110.9 km/h
Voltage: 14.14 V
Temperature: 258.0C
(no units): 0.00
(no units): 0.55
(no units): 1.37
Readiness: 1 1 0 0 0
2005 B5.5, TD Tuning, R783s, GTB2260VK, 6 speed O1E, BSM 2/09, Pod w/ 40 PSI & EGT Gauge, Thor Skid Plate, Cat FF, Euro switch
1996
B4V, 2.0L w/ BHW pistons, Rosten Rods, Girdle, 11mm, GTB1756vk, RC6, PP764s, .622 5th, Colt Cam II, Ecodes W/leveling motors & Euro switch, fog lights, Koni Yellow, Cat FF, Whitbread 2.5" DP, exhaust, FMIC
Sprocket is offline   Reply With Quote
Old June 3rd, 2015, 21:41   #59
stephane
You may be looking at a Nox sensor replacement near the Nox catalytic converter. This is the revised part number (for 2012 passat) -> 03L 907 807 AD
Not 100% sure but this is most likely your problem, not the adBlue tank sensor.
Got mine from amazon for 330+. Dealer quoted me $1020+ for the part only. Be weary of dealers.
Edit: Part number for 2010 Touareg would be 059907807H for front Nox sensor and 059907807G for rear sensor.
stephane is offline   Reply With Quote
Old June 4th, 2015, 00:07   #60
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
Hey guys....
Got room for one more in this clubhouse? =^(
CEL came on last night at 41,xxx miles. So just outside of warranty.
Came back with code P205C Reductant Tank Temperature Sensor Short to GND
No previous hints of impending failure.
Fortunately I bought the Fidelity Platinum extended warranty when I bought my car so they will be picking up the tab.
Since it is not a level sensor failure, I am not getting a "xxxx miles to no start". So I will continue to drive it while I wait for the part to come in. It is on back order so they said about a week.
The good thing is that since I now work at my servicing dealer, I will know the minute it comes in. I HATE seeing the CEL on...
Fixmy59bug is offline   Reply With Quote
How to: Replacing the Adblue Heater & Temp Sensor Module docmanny VW Passat Family (NMS and B7) TDIs (2012+) 106 March 2nd, 2017 05:26
AdBlue and Fuel Pump Failure AtlantaRene VW Passat Family (NMS and B7) TDIs (2012+) 72 October 2nd, 2016 22:21
Survey; P202A.. AdBlue Heating Element., et.al., ZootsAlures VW Passat Family (NMS and B7) TDIs (2012+) 31 March 5th, 2016 20:35
Seat heater element swap? BlueCTTDi Upgrades (non TDI Engine related) 22 October 21st, 2005 16:24
Seat heater element replacement pghPAtdi VW MKIV-A4 TDIs (VE and PD) 11 December 21st, 2003 16:35
Page generated in 0.15069 seconds with 11 queries
[Output: 129.77 Kb. compressed to 108.58 Kb. by saving 21.19 Kb. (16.33%)]
