Old April 24th, 2015, 09:33   #31
spjackson1
Update to previous post regarding ADBlue heater/level sensor code P203B and O2 sensor stuck. Spoke with VWofA explaining the circumstance with the cost and timeliness of this fault, and they are offering to pay the dealer for the repair of this problem (approx $1500). That is definitely a positive response that gives me more confidence in VW.
spjackson1 is offline   Reply With Quote
Old April 26th, 2015, 21:09   #32
VWrussell
Default Cheap DIY Fix for P205c & P205b Temp Sensor
Hello,
This is my first post as a new member to TDI club.
I recently had the Check Engine Light come on with the P205c/P205b fault codes. I did some extensive research because I did not want to spend $475 on a new part to fix this as my Passat just went out of warranty.
The failed temperature sensor is integrated inside the AD Blue Tank and you cannot change this sensor out at the component level. The part number that contains this sensor is 561-198-970.
This temp sensor monitors the temperature of the DEF fluid and if it drops below -11 Degrees Fahrenheit then it activates the heater inside this tank. Since I live in Texas I don't really have to worry about -11 degree temperatures here. There are two ways to fix this issue yourself if you do or do not live in a climate where the weather gets below -11.
before you start, purchase a 10k Ohm Resistor or Automotive grade 10k Ohm Submersible Thermistor, Solder, heatshrink.
Mouser Electronics or eBay are two places to find these components.
Once you have all your parts ready, Here are the steps to take:
  • Use the jack in your trunk to lift up the rear passenger side until the tire just barely comes off the ground.
  • Remove all the torx screws that are around the rear fender well.
    There should be 5 of them if I'm not mistaken.
  • Pull out the plastic part of your lower bumper/quarter panel.
    Just enough to give you a few extra inches for removing the tank.
  • The tank is held in place by 3 bolts, remove them and drop the tank down. (Be ready to catch it if it's full of DEF as it will be heavy)
  • Find the Wire harness that is secured to the filler neck of the tank.
  • Pins 3 & 4 are the temp sensor wires connected to the failed temp sensor inside the tank. They are purple/yellow and Brown and on the other side of the connector going into the tank the colors are Black & White.
Easy Fix option if you're lazy or live in a warm weather climate:
  • From the other side of the plug, cut the wires that are going into the tank (Black & White wires) . Make sure to leave enough slack for the resistor or thermistor.
  • Solder & heatshrink a 10K ohm resistor or 10k OHM Thermistor to the cut wires. Make sure that the connections are made back to the computer and not to the tank. Leave the wires from the tank cut off and just use some tape or heat shrink to protect them as they will never be used again.
For Cold Climate Areas:
  • Take a picture of the tank before you start, ensure you know the position of all the cables, hoses and top pump position.
  • Remove all the harness, Hoses and Pump from the Top of the tank.
  • Unscrew the Top of the tank and remove the rubber grommet and plastic circular housing from the tank. The circular housing is locked in, just twist it counter clock wise and it will become detached from the tank.
  • Find/trace the wires inside the tank that are associated with pins 3 & 4 on the outside of the tank. (black & white wires.)
  • Using a Submersible Automotive Grade 10k Ohm thermistor,
  • Solder/Heatshrink the thermistor to these wires and make sure the probe part of the thermistor is located in the small part of the tank with the other sensors. Some Drilling may be necessary.
As I live in Texas, I did not pursue or try the Cold Climate option I described above.
Also, as I was troubleshooting this issue, I actually drilled a small hole in the plastic and extended the wires so I could access them from my trunk when I was trying to figure out the correct resistor to use.
At the time I was not sure what resistor size to use. After trying different values. I borrowed a friends 2014 TDI and used my meter to find the value VW uses for this component.
The 10k Ohm Resistance reading is equal to 25 degrees Celsius or 77 degrees Fahrenheit. This resistance reading will make the computer think the DEF fluid is at this temperature.
In the pictures attached I show the connections to look for.
(See Links below)
If you don't want to drop the tank, another option is to cut the wires from the connector by the rear wheel and add the resistor or thermistor from there. It also uses pins 3 & 4 on one of the wire harnesses.
Once I added the 10K Ohm resistor, it took me about 4 days of everyday driving before my Check Engine Light went out. I'm not sure of the exact number but the computer needs to go through a certain number of "driving cycles" before it realizes the problem is fixed and the light goes off.
One more thing to note if your adblue tank is full, unplug the harness/hose and dump all the DEF fluid into a large clean container.
This will help out as its very hard to get the tank bolted back into position. Once the nearly empty tank is bolted back in place, just re-fill it as you normally would. I use the small Filler bottle from VW. I have a hole cut out in the bottom of it and use a funnel to re-fill that small bottle. Once its full I push the bottle down to let the DEF enter the tank. Repeat until your full....
I hope this post helps.
No sense in spending close to $500 when you can replace this with a resistor or thermistor that costs less than a dollar. (And an hour or two of your time)
~Russ
Pictures to help you:
http://i81.photobucket.com/albums/j2...h/IMG_2307.jpg
http://i81.photobucket.com/albums/j2...h/IMG_2305.jpg
http://i81.photobucket.com/albums/j2...h/IMG_2303.jpg
VWrussell is offline   Reply With Quote
Old April 28th, 2015, 07:00   #33
aullein
Originally Posted by VWrussell View Post
Hello,
(See Links below)
~Russ
Wow I mean Wow!!! Mega Props to you my friend!! If this truly works for everyone's issue what a money saver this is. Thanks for taking the time to experiment on your own car and then writing it up on here. Im F$kin stoked as being I'm in Fl. 500$ is just for the part... you have another couple hundred at least in labor!! big time saver
FYI i could not get the pictures to work
aullein is offline   Reply With Quote
Old April 28th, 2015, 08:43   #34
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
That's a great plan until you travel north. AdBlue freezes at -11 Celsius, which is +12.2 Fahrenheit.
Trusted TDI Mechanics Map || TDIClub Chat
VeeDubTDI is online now   Reply With Quote
Old April 29th, 2015, 10:40   #35
paver
TDI(s): 2013 Treg
Year: 2013 Treg
Mileage: 50,500
Warning Light(s): Steady CEL
Code(s): P202A and P202B
Any symptoms or problems before diagnosis: may be unrelated but particulate sensor needs replacement. CEL for this came 1000 mi before tank heater issue.
paver is offline   Reply With Quote
Old April 29th, 2015, 12:23   #36
aullein
Originally Posted by paver View Post
Year: 2013 Treg
Mileage: 50,500
Hey Paver just a heads up I drive a '12 passat and I have a P202B code as well. Our systems are identical I believe just diff vehicles. I have been driving with the CEL on since beginning Feb and prob close to 4k miles and nothing else has occurred. I'm not saying don't ge it fixed but in case you dont feel like dropping the $$ for it now you should be ok to drive unless you get a countdown. I haven't experienced any other CEL's or issues with the car since it has come on. You could be ok for a while living in the south
Old April 29th, 2015, 14:55   #37
paver
TDI(s): 2013 Treg
Thanks...I just ordered the parts. I'm going to try to fix it myself. Found a good step by step guide with photos on ClubTouareg.
Old April 29th, 2015, 20:18   #38
dministrator
Originally Posted by dministrator View Post
2012 Passat TDI SE
about 41,800 miles
P205B - Reductant Tank Temperature Sensor Circuit Range Performance.
I got MIL two days ago; reset using the app. It was fine for a day and came on again this morning. Hopefully the extended warranty covers it.
It is being taken to the dealership now, I'll post an update when I know more. Like someone said on another thread, all the savings we achieve in fuel is meaningless if we have to shell out big $$$ for service.
Update 4/30/2015:
It is covered by fidelity extended warranty. The concerned part was on backorder status. When I asked the service tech if he has seen the same failure before in this or comparable models, he said no. He also speculated that if a part is on backorder, it is very likely becoming a common issue.
Update 2:
It cost me $100+$7 in NJ Tax for Fidelity's deductible. I tried to complain about this to VWOA; $107 is no small amount for us. But they said it is not their charge but Fidelity's. Just because the original warranty is over, doesn't mean they are free of their responsibilities.
dministrator is offline   Reply With Quote
Old May 11th, 2015, 08:56   #39
Softrockrenegade
Softrockrenegade's Avatar
Guess I can join the club. MIL light on at 78k with a P205B code. Has anyone with geico MBI had to file a claim with it. Talked to a Indy shop today and they seemed hesitant to want to deal with a insurance claim.
Softrockrenegade is offline   Reply With Quote
Old May 11th, 2015, 10:10   #40
kydsid
TDI(s): 2012 Passat
Mad props he figured that out but another caveat is emissions. DEF effectiveness is temperature dependent. This is why its heated and there are temp sensors all over the scr system. A car with this mod may fail emissions checks if a sniffer probe is used as the def rate may be incorrect for the NOx emissions being produced.
504/507 Oil retail source list - http://forums.tdiclub.com/showthread.php?t=360912
kydsid is offline   Reply With Quote
Old May 14th, 2015, 13:36   #41
skinnyb
TDI(s): 2013 JSW TDI
Fuel Economy: Slightly north of 40 MPG
69800 mi.
CEL
P203B - Reductant level sensor
no indications of failure until CEL came on.
Repair Time: estimated 1 day
Scanned with VCDS and took print out to dealer. Talked to service advisor who had seen this problem before. Verified that parts are in stock and setup appointment for next week. Will be covered by fidelity platinum warranty with $100 deductible.
2015 Passat 1.8T Limited Edition
2013 JSW TDI DSG Malone 2.0 Eco, Tint, Wheels, Etc...
skinnyb is offline   Reply With Quote
Old May 15th, 2015, 04:54   #42
jreed2528
TDI(s): 2012 passat
2012 Passat TDI SE
P202a and P202b codes
Been driving it for a couple months now with the engine light on, nothing different other than looking at the engine light. Purchased a heater unit, just waiting for the DEF tank to be empty.
jreed2528 is offline   Reply With Quote
Old May 19th, 2015, 15:35   #43
toddoxley
I have a 2013 Passat TDI SEL, Purchased new and have 57500 miles. 3 weeks ago the adblue light came on indicating 1500 miles to go, at 600 miles to go I filled it with 2.5 gallons of Peak DEF.
This adblue fill was my second time to do this myself as dealer had topped it off at 10k, 20k and 30k scheduled maintenance .
The day after I filled it the CEL came on and I went to O-Reillys and the code was P-205B " Reductant Tank Temperature Sensor". After reading this thread on the subject and realizing this was a 1000.00 + fix I called the dealer in Phoenix that I purchased the car from and they gave me VWOA phone #, I called and filled a complaint and was given a case # and was told to schedule a service appointment.
They called me today and stated that VWOA would pay 75% of the cost to replace the adblue sensor and I would owe 217.00.
I am very happy with his outcome but am very concerned about the long term cost of maintaining this car.
I have had minor issues with the car ie: leather seats cracking, high pressure fuel line leaking, blower motor squealing and wind noise from three windows and sunroof.
Good Luck to all of you who are having similar issues..
toddoxley is offline   Reply With Quote
Old May 20th, 2015, 18:28   #44
ZootsAlures
Default UNOFFIAL Adblue Heater Element Failure Thread
I too got caught in this web of AdBlue component failure-
2012 W/73k miles. Threw a 0202A hard code (Cleared and returned four times in less than 40 mile intervals).
VW Service informed me that it may be one of three related issues: Sensor, Module, or Heating Element. In order for them to fully diagnose the problem they disassembled the rear bumper et.al., and pointed to the costliest repair- the heating element. Est. T&M = $1,200. Part needed to be ordered but at least I was given use of their Loaner for the next two- four days.
Up until this incident my car ran flawlessly.. I always topped off the AdBlue when the descending counter was between 5k -3.5k miles left. Oil & Filter between 1k-1.5k miles left. Here's the funny part-
Received three mailers and one phone call from VW trying to buy my "Highly desirable "'12 6MT" IN TRIPLE BLACK. Each offered me to choose any new (Similar) car with $0 out of pocket at 0% up to 72 months.
Yup, right after I pick mine up from a three or so day layover from VW Service.....
2012 Passat TDI SE. 6SpM
ZootsAlures is online now   Reply With Quote
Old May 21st, 2015, 14:05   #45
ZootsAlures
PARTS UPDATE: I was told the replacement element will arrive late next week. Blasphemous! I'm going through... Wait for it- TDI Withdrawals!
AdBlue and Fuel Pump Failure AtlantaRene VW Passat Family (NMS and B7) TDIs (2012+) 76 April 8th, 2018 08:24
How to: Replacing the Adblue Heater & Temp Sensor Module docmanny VW Passat Family (NMS and B7) TDIs (2012+) 108 February 27th, 2018 19:54
Survey; P202A.. AdBlue Heating Element., et.al., ZootsAlures VW Passat Family (NMS and B7) TDIs (2012+) 31 March 5th, 2016 19:35
Seat heater element swap? BlueCTTDi Upgrades (non TDI Engine related) 22 October 21st, 2005 15:24
Seat heater element replacement pghPAtdi VW MKIV-A4 TDIs (VE and PD) 11 December 21st, 2003 15:35
Page generated in 0.19116 seconds with 11 queries
[Output: 142.24 Kb. compressed to 121.03 Kb. by saving 21.21 Kb. (14.91%)]
