Old February 23rd, 2017, 07:07   #391
Yankinwaoz
VW replaced my AdBlue heating element under warranty for free. My car has 110323 miles, and is from 2012. So it cost me nothing. I am very pleased with their response.
The dealer did this in one day. I dropped it off Tuesday morning and it was ready Tuesday afternoon.
The repair paperwork says "Found 1 DTC for Adblue tank heater element control circuit low. Checked wiring and connections. No problems found. Per tech bulletin #26-16-05 replaced AdBLue header element. Performed leak test and reset ECM."
Yankinwaoz is offline   Reply With Quote
Old February 23rd, 2017, 08:37   #392
Mark_J
2013 Passat SEL Premium, 46,000 milesgot the CEL light yesterday. Cleared it for giggles. Chatted with VW and mine is covered under the extended warranty. So if it comes back will book and appointment.
1 Fault Found:
9656 - Control Circuit for Reductant Tank Heating
P202B 00 [237] - Short to GND
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 75253 km
Date: 2017.02.22
Time: 04:56:42
Engine speed: 1483.50 /min
Normed load value: 71.0 %
Vehicle speed: 78 km/h
Coolant temperature: 44 C
Intake air temperature: 28 C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 14.120 V
Unlearning counter according OBD: 40
Outside air temperature: 1.0 C
Exhaust gas temperature sensor 4: 285.6 C
Sensor for reducing agent tank temperature: temperature: 4.8 C
Heat circuit 2 for reduc. agent meter. system: act. voltage: 136.6 mV
Heat circuit 1 for reduc. agent meter. system: act. voltage: 586.2 mV
Mark_J is offline   Reply With Quote
Old February 27th, 2017, 06:57   #393
rustycat
51K on my Nov 2013 SEL and just had the repair done. I had a great experience with the dealer and for that reason I'll give that dealership a high recommendation. The Dealer is VW of Olympia. BTW, I've tried 4 other dealers in the Seattle area and could not recommend any of them.
rustycat is offline   Reply With Quote
Old February 27th, 2017, 14:28   #394
Mark_J
Wish VW of Olympia was closer. I live in Deer Park Wa, N of Spokane but work in NW Wa. so I am close to the Canadian border.
Old March 8th, 2017, 03:42   #395
Fastbird
Just had my throw a P202B code yesterday morning.
2012 SEL
115xxx miles
If it pops again I'll get it to the dealer for the fix.
Fastbird is offline   Reply With Quote
Old March 8th, 2017, 11:07   #396
shak911
2012 SEL
115xxx miles
You're very close to the expiry mileage of the extended warranty of 120,000. miles.
my code (p202 would return 2 restart after reset.)
shak911 is offline   Reply With Quote
Old April 13th, 2017, 03:41   #397
Fastbird
Just got a P202A this morning leaving work. 1166xx miles this time. Making an appointment ASAP.
Old April 14th, 2017, 05:28   #398
Rico567
By all means get in to the dealer and get the code documented. Even if the code goes away before you get there, at least there'll be a record of it and I'd think you'll have a good shot at a free repair even if you go over 120K.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old April 14th, 2017, 05:29   #399
Fastbird
Sitting at the dealer right now. Already have a positive diagnosis, appointment for next Wednesday to have the repair kit installed. They're even washing my car for me right now.
Old April 14th, 2017, 12:42   #400
TDIpstick
Cool Waiting to pass "go" and collect my $21k
2012 Passat
CEL
79,839 miles
3 Faults Found:
9688 - Reductant Tank Temperature Sensor
9687 - Reductant Tank Temperature Sensor
15733 - SCR NOx Catalyst Bank 1
no symptoms, no repairs yet, going to see if dealer will fix it under warranty, no risk of freezing in FL
TDIpstick is offline   Reply With Quote
Old April 14th, 2017, 16:12   #401
Tinkertoy
my pump crapping out was part of the reason i took the buyback offer. i backed in to something that must have jarred the pump, I was getting a temp out of range or low pressure code (I forgot what is was exactly). it was not covered under warranty.
that repair, along with the timing belt, tires, brakes, deductible for bodywork, etc would have hurt bad.
I applied the restitution money towards a new SEL gasser, which I love.
Tinkertoy is offline   Reply With Quote
Old January 22nd, 2018, 06:14   #402
roni024
My MIL on my 13 DSG SE lit up over the weekend. Scanned with VCDS and found code P202A: Reductant Tank Heater Control Circuit. Car has roughly 135k on it, so warranty coverage is not expected.
I have suspicion that the failure is most likely caused by crystallized urea building up somewhere on the AdBlue heating element, level sensors, or inside the pump itself. I'm planning to attempt repair to see if I can dissolve these crystals and restore functionality. My plan is to siphon and remove as much DEF fluid as possible from the tank, then fill to brim with heated (maybe boiled) distilled water with some isopropyl alcohol added in (say 1/2 cup alcohol to gallon of water). I'll immediately take the car on a little roadtrip (1-2 hours highway driving), then empty the water and refill with DEF.
Has anyone tried something similar and can report your findings? What are the risks involved with running the car with water instead of DEF for a short time?
roni024 is online now   Reply With Quote
AdBlue and Fuel Pump Failure AtlantaRene VW Passat Family (NMS and B7) TDIs (2012+) 76 April 8th, 2018 08:24
How to: Replacing the Adblue Heater & Temp Sensor Module docmanny VW Passat Family (NMS and B7) TDIs (2012+) 108 February 27th, 2018 19:54
Survey; P202A.. AdBlue Heating Element., et.al., ZootsAlures VW Passat Family (NMS and B7) TDIs (2012+) 31 March 5th, 2016 19:35
Seat heater element swap? BlueCTTDi Upgrades (non TDI Engine related) 22 October 21st, 2005 15:24
Seat heater element replacement pghPAtdi VW MKIV-A4 TDIs (VE and PD) 11 December 21st, 2003 15:35
Page generated in 0.16917 seconds with 11 queries
[Output: 107.34 Kb. compressed to 91.09 Kb. by saving 16.25 Kb. (15.14%)]
