Old April 13th, 2015, 19:08   #1
dee74
TDI(s): 2012 Passat
Arrow UNOFFICIAL Adblue Heater Element Failure Thread
I have been reading a few threads on the failure of the Adblue heater Element lately and I thought I would start a thread to see if this is becoming a trend, my TDI is in the shop now with this same problem. Please list the following Info:
Year
Mileage
Warning Light(s)
Code(s)
Any symptoms or problems before diagnosis
Repair Time:
Any pertinent info from dealer
My Car
2012
58???
CEL
P205B
Large variations in mileage
Estimated 4 days
No info shared, repair is not covered under emissions warranty
dee74 is offline   Reply With Quote
Old April 13th, 2015, 20:04   #2
ajharbin
ajharbin's Avatar
32,000
CEL
9688 reductant tank temp sensor and 2. 5523 engine start blocked by immobilizer
no symptoms of issue besides CEL
after getting the run around with VWoA it took 2 trips and on the second trip it took 4 days to repair.
Dealer said they have replaced a few of the sensors on other tdi models (ones that have DEF) but did not say they were a real issue. just turned over 40k and have not had any issues since the repair.
ajharbin is offline   Reply With Quote
Old April 14th, 2015, 08:19   #3
Sigforty
Not sure if you want to count it, but my level sensor failed which is part of the same module.
Sigforty is offline   Reply With Quote
Old April 14th, 2015, 09:42   #4
dee74
TDI(s): 2012 Passat
Yes we will count sensor failure. I think mine may only be the temperature sensor, not sure yet, but the part only comes as a complete module with all of the sensors.
Old April 14th, 2015, 10:05   #5
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Temp sensor failure @ 80,000 miles. Heating element is fine. I'll have to get more details from Jason, since he is the one who scanned it.
No repair attempt yet... still driving it with no issues other than a check engine light.
Trusted TDI Mechanics Map || TDIClub Chat
Old April 14th, 2015, 11:24   #6
TheGrove
I would also like to know how low you usually ran your AdBlue before filling. Did you fill it at every service or wait for the warning before filling. Just wondering if there is a correlation or not.
2012 Passat SEL Premium TDi Opera Red
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
TheGrove is offline   Reply With Quote
Old April 14th, 2015, 14:42   #7
Blackie TDI
2012 Passat TDI. Current mileage 88,200 mi. This is what i have had replace so far in one month time frame (3/02/2015). 1. part # 7N0941329 control unit for reduction. control unit for reduction; agent metering system. 2. part# 3C0906651 evaluation unit for reduction. evaluation unit for reduction; agent reserve. 3. part # 561198970 heater element repair kit. Replace 15 days ago, check engine light back on took to vw dealer scan showing same code for heater element in adblue tank. Part # 561198970. Called Vw and waiting for answer on what they are going to do.
Blackie TDI is offline   Reply With Quote
Old April 14th, 2015, 16:33   #8
Good Ol' Boy
VeeDubTDI's Avatar
We fill at every 10K service. I think it only counted down once because Jason wanted to see it count down.
Old April 15th, 2015, 05:40   #9
TheGrove
Sounds like me, thanks. So far no problems here (crossed fingers).
Old April 15th, 2015, 08:16   #10
Sigforty
54944 mi.
CEL
P203B - Reductant level sensor
no indications of failure until CEL came on.
Repair Time: 1 day
They ran GFF and found faults for level sensor passive sporatic, ran test plan and found wiring was ok, so they replaced the sensor module. Cost was $1050 of which I paid $50 deductible on the certified warranty.
Old April 15th, 2015, 22:18   #11
jrm
Fuel Economy: 42/52
im keeping mine full to prevent corrosion, only complaint is its easy to overfill- not a lot of sound change as it fills to the brim. Lucky for me I stuffed towels all around the filler
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old April 16th, 2015, 07:04   #12
compu_85
Gadget Guy
compu_85's Avatar
We fill {the adblue tank} at every 10K service. I think it only counted down once because Jason wanted to see it count down.
It's been filled every 10k, and has never entered the countdown phase.
The sensor fault is intermittent. The CEL has been on and off a few times now.
-J
Present:
2013 Fiat 500e. 18,000 miles. Almost 100 miles per charge!
Past:
Old April 16th, 2015, 15:16   #13
Good Ol' Boy
VeeDubTDI's Avatar
Well there you go. Shows what I know.
Old April 17th, 2015, 07:15   #14
Bobmws
I bought 1 bottle from the dealer that has the shutoff nozzle. If you take a hacksaw to the "childproof" lock on the cap you can refill the bottle. No muss, no fuss, no spills.
Bobmws is offline   Reply With Quote
Old April 17th, 2015, 07:32   #15
mtbsteve
Year: 2012
Mileage: 52,743 miles
Warning Light(s): Check Engine, not flashing.
Code(s): P205B
Any symptoms or problems before diagnosis: Car was fine - cleared code, kept coming back.
Repair Time: 1 day to diagnose at dealer (even though I determined the error via Torque App and VAGCOM, 1 day to repair.
Any pertinent info from dealer: Dealer said that it would not be covered. I did a lot of research and I still believe that states that follow the CA emissions warranty should be covering this but they do not. I am in MA.
I have stated this info in more detail in an older post but in the end I was able to buy the part through the dealer using the online parts ordering before I booked the appt to fix it. They were not happy and tried to block and charge full retail but was able to get the part for $461. In the end I contacted VW who eventually paid for the part cost by cutting me a check since I have always (except once) had my car serviced at dealers and this should not fail.
Total cost breakdown:
$115 for diagnoses
$461 for part - I think retail it is $625+ for PN 561198970 (VW eventually reimbursed $461)
$315 labor
$20.95 shop charge
$11 urea
Last edited by mtbsteve; April 17th, 2015 at 07:36. Reason: added MA location for reference
mtbsteve is offline   Reply With Quote
How to: Replacing the Adblue Heater & Temp Sensor Module docmanny VW Passat Family (NMS and B7) TDIs (2012+) 106 March 2nd, 2017 05:26
AdBlue and Fuel Pump Failure AtlantaRene VW Passat Family (NMS and B7) TDIs (2012+) 72 October 2nd, 2016 22:21
Survey; P202A.. AdBlue Heating Element., et.al., ZootsAlures VW Passat Family (NMS and B7) TDIs (2012+) 31 March 5th, 2016 20:35
Seat heater element swap? BlueCTTDi Upgrades (non TDI Engine related) 22 October 21st, 2005 16:24
Seat heater element replacement pghPAtdi VW MKIV-A4 TDIs (VE and PD) 11 December 21st, 2003 16:35
Page generated in 0.20373 seconds with 11 queries
[Output: 133.33 Kb. compressed to 111.72 Kb. by saving 21.61 Kb. (16.21%)]
