Old January 10th, 2015, 09:18   #46
tdiatlast
All this excitement. How many failed heater cores have been confirmed?
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old January 10th, 2015, 15:59   #47
Not_Agn
More then there ever should be!
Not_Agn is offline   Reply With Quote
Old January 10th, 2015, 17:39   #48
tdiatlast
Still awaiting some sort of proof of a plugged heater core, and not something involving the sometimes troublesome flapper motors/blend doors.
Old January 10th, 2015, 17:51   #49
Not_Agn
Well I'm glad they are not charging me the total bill. But seeing as they are charging me anything, I think I'm buying the heater core. There fore should be able to retrieve the old one, right?
Old January 10th, 2015, 17:54   #50
tdiatlast
Unless it's an official VAG warranty repair, you're buying the parts, and should be allowed the old parts. At least you should be allowed to see the "defective" part.
Sorry for your trouble.
Old January 10th, 2015, 23:15   #51
sdeck
sdeck's Avatar
Originally Posted by VeeDubTDI View Post
Ford had a problem with casting material in the 6.0 engine clogging up oil coolers, which in many cases lead to cascading failures of EGR coolers and head gaskets. Something similar could be happening here, but we will need someone to cut open a clogged heater core to know for sure.
If this is the cause of the problem, adding a coolant filtration system will solve the problem by catching the material in the system.
I had the same thought. If casting junk clogged up the heater core, what did it do yo my radiator and water pump? I am definitely going to press them on this on Tuesday.
"If you make it idiot proof, nature will build a better idiot"
Considering WVO? see these:
http://forums.tdiclub.com/showthread.php?t=213288
http://forums.tdiclub.com/showthread.php?t=249556
sdeck is offline   Reply With Quote
Old January 12th, 2015, 11:41   #52
phat02jetta
Fuel Economy: 48/45/43 - 47/43/37
I've an appointment for mine to be replaced tomorrow, but they said I can't keep the old core.
I'm also having the fender liner/blower intake mod done at the same time, so my blower motor hopefully won't keep freezing up.
phat02jetta is offline   Reply With Quote
Old January 12th, 2015, 12:00   #53
radunegru
Fuel Economy: 42.5
After few days at the dealership diagnostic is clear: heater core.
Unfortunately is on back order. Also the dealer worked it out very well, provided me a loaner and said that it will be covering the repair even though it was a bit over the warranty I was explaining them that I have this issue for some time. It wasn't that obvious until this recent cold front that affected most of the country.
radunegru is offline   Reply With Quote
Old January 12th, 2015, 12:26   #54
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
If they won't give you the old core, at least get your hands on it and blow through it. You should be able to tell if there is a significant restriction or not.
Trusted TDI Mechanics Map || TDIClub Chat
Old January 12th, 2015, 13:40   #55
psd1
Fuel Economy: See Fuelly link
And have someone take a picture this and post it here...
psd1 is offline   Reply With Quote
Old January 12th, 2015, 13:44   #56
Good Ol' Boy
VeeDubTDI's Avatar
I'd really like to see what's inside. Is it sludge? Is it sand? Is it a piece of plastic that got sucked in and stuck?
Old January 12th, 2015, 15:08   #57
Not_Agn
Thought I was doing good with only being charged the $225. But seeing dealers covering it completely had me thinking I'm going to talk to the dealer when I pick it up. Or should I just call VoA now and see what they say?
Old January 12th, 2015, 16:03   #58
ABS
ABS's Avatar
Fuel Economy: Fuelly
I will ask if I can have mine after they get it fixed. Repair date is TBD, pending the parts. If they do, I will cut it in half for a closer look and pictures. If they will not give it to me, I will ask if they can cut it and let me take pics... No gaurantees, but I will definitely try to get my hands, or camera on it.
In Garage:
2014 Passat SE TDI, 6-m/t, Tungsten Metallic
2002 BMW E46, 5 m/t, Oxford Green Metallic
2006 Honda Odyssey Touring
ABS is offline   Reply With Quote
Old January 12th, 2015, 16:47   #59
Confused
Most warranty replaced parts must be kept by the dealer incase the manufacturer wants it shipped back for failure analysis.
Confused is offline   Reply With Quote
Old January 13th, 2015, 08:48   #60
sdeck
sdeck's Avatar
Just dropped mine off. Service tech said the inlet is on the drivers side, outlet on passenger side. Restricted flow would mean all the heat gets removed before it gets to the passenger side. Makes sense to me. Had said these heater cores are pretty small and are the smallest restriction. He has heard of a few "exploding" (his word) and leaking coolant all over the cabin floor, which is why they are replacing them. He also assured me there have been no issues with radiators.
Rusty coolant and clogged heater core sweetlou132 VW MKV-A5 Golf/Jettas 24 March 5th, 2017 17:13
'10 GOLF TDI, NO HEAT (passenger side), Driver side gets HEAT? Clogged heater core. RomanL VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 33 March 23rd, 2015 11:23
Heater Core/Blend Door/Heat Problems - Noise from Dash tug VW B5 Passat TDIs 2 April 9th, 2012 10:41
Heater core? Very little heat IanFlo TDI 101 2 October 2nd, 2007 18:09
Heat still smells like antifreeze when new heater core installed?? Magic99 TDI 101 2 June 12th, 2007 13:07
Page generated in 0.14237 seconds with 12 queries
[Output: 129.50 Kb. compressed to 108.31 Kb. by saving 21.19 Kb. (16.36%)]
