Old July 6th, 2014, 16:44   #31
n1acguy
Just looked at the Passat and these batteries are totally sealed.
Can't tell for sure, but it appears to be either a gel type or AGM.
It's in a location where it's likely to get plenty of heat even with the insulation around it.
Alex
My 2 YMMV
n1acguy is offline   Reply With Quote
Old July 6th, 2014, 21:10   #32
axnels2
I have not had very good luck with batteries on my 09 JSW. First died just 2 years into the life. Replaced under warranty. The next one lasted a bit over 3 years... On my 3rd one now. I am guessing the heat on the CR/DPF kills these batteries quicker on MKV and later cars.
2009 DSG TDI JSW
16 inch ditto wheels, gorilla protection package, ipod adapter, panzer plate, yakima roof rack.
"Don't bother me with facts, Son. I've already made up my mind." -Foghorn Leghorn
axnels2 is offline   Reply With Quote
Old July 25th, 2014, 11:50   #33
Misterdenali
My 2011 Jetta TDI had the same issue. Sudden dead batter, 0 Amp output when I tested it at Advance AutoParts. New battery, but had an issue with a dead glowplug in cylinder 1 immediately afterwards. Wondering if trying to jump a completely dead battery did something there.
Back in action after 3 days at the dealer (trying to figure out the cylinder 1 error).
Misterdenali is offline   Reply With Quote
Old July 31st, 2014, 10:57   #34
goldgary
When replaceing battery, if one uses a memory saver plugged into cig. lighter port, does that save error codes, in addition to saving radio stations, clock, ect. ?
goldgary is offline   Reply With Quote
Old July 31st, 2014, 10:59   #35
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
I've never tried doing that. It wouldn't work on the Passat anyway because the power port is disabled when the ignition is off.
Trusted TDI Mechanics Map || TDIClub Chat
Old July 31st, 2014, 15:43   #36
BPofMD
Mine is still going... since I bought it April 2012.
2012 Passat TDI SE (Awaiting 3/9/17 Buy-Back)
2015 Lincoln MKZ Hybrid
2005 Ford F250
2007 Arctic Fox 5th Wheel
BPofMD is offline   Reply With Quote
Old July 31st, 2014, 16:10   #37
vw_norm
Gone, but not forgotten.
^^^what he said, but from May of 2012. At one point in time, I found a measuring block in the ECU that showed total number of starts. A few version of VCDS later, I cannot find it anymore. Anyone recall seeing this MB? I was thinking this would be a good measure of battery life, since the starter motor is generally the largest amperage pull on the battery and the MB would be a good measure of durability.
vw_norm is offline   Reply With Quote
Old August 1st, 2014, 06:11   #38
tdiatlast
Nope. The vinyl label has you fooled. Peel it off, and you'll find normal acid wet-cell caps underneath. Also note the white vent/overflow cap on the front side.
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is online now   Reply With Quote
Old August 1st, 2014, 12:26   #39
n1acguy
Thanks!
I caught it just before the plates were exposed. Topped it up with distilled water. Should be good for another year.
Alex
My 2 YMMV
Old February 15th, 2017, 22:30   #40
767wrench
Fuel Economy: 37-43
Just now replacing the original battery in my car, bought new in April of 2012. Currently at 128500 miles. Sounds like a record for what I've read on these cars. I wonder if doing the DPF delete early on helped prolong the life by getting rid of excessive heat.
The resting voltage is at about 12 and it's barely starting the car and failed to once now. Charging system is working fine at around 14 volts. I knew something was up a few weeks ago when my interior lights didn't come on when I got in. Theres a shutoff once the battery gets low enough. I'm going to go with an Optima yellow top.
12' Passat SE TDI; Cr 170 Turbo, Stage 3.5 malone, dpf, egr, muffler delete, traction control delete button, Sachs SRE Performance clutch with DMF, KONI Sport suspension, H&R lowering springs, Fluidampr by INA engineering, mini train horns, HID 10K projector headlights with LED DRL, painted brake calipers, ID parts winter front, frost heater, 19" Enkei Raijin - GONE TO BUYBACK
767wrench is offline   Reply With Quote
Old February 16th, 2017, 04:56   #41
Rico567
Checking back into this thread. Even though it's three years since I did, the nature of the thread would seem to exempt it from "zombie" status. The OEM battery in our Passat, bought new in July '13, is still working fine. Based on what I've read here, I may dig into it and try to expose the cell caps and top the thing up with distilled H2O.......
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is online now   Reply With Quote
Old February 16th, 2017, 09:04   #42
buzzie0013
buzzie0013's Avatar
Replaced our in our '13 maybe 6 months ago. Our car had about 72k on the clock. Car started acting funny, random dash lights coming on, not starting (obviously) and the dash clock acting haywire. new battery, everything loke normal again.
2013 SEL TDI Platinum Gray w/Titan Black & Wood Trim
buzzie0013 is offline   Reply With Quote
Old February 16th, 2017, 14:28   #43
Lex Tdi
TDI(s): 2013 Passat
Still have the original...
2013- Passat SE DSG 120,000 miles
RIP 2003 Jetta - 444,000 miles
SOLD 2001 Jetta - 300,000 miles
Thanks to Paramedick (Bruce) for being my local Guru for over a decade!
Lex Tdi is offline   Reply With Quote
Old February 17th, 2017, 11:48   #44
VernK
A gasser, but still on the original battery here four and a half years in.
Yours
Vern
VernK is offline   Reply With Quote
Old February 17th, 2017, 14:16   #45
Rico567
Had a chance today to check the electrolyte level in the Passat's battery. The labels stripped right off, but the only cell that was a bit down (took maybe 1-2 ounces) was the one nearest the negative terminal, the rearmost one. So that looks pretty good for a battery that's going on 4 years old.
- Adam Savage
How long did your battery last? wsktdi VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 137 November 14th, 2016 15:27
Battery Failure? (Long) ColoradoDriver VW Passat Family (NMS and B7) TDIs (2012+) 46 October 21st, 2012 21:01
How long did your OEM battery go? deezelpower VW MKIV-A4 TDIs (VE and PD) 34 February 7th, 2007 23:43
How long does a battery last amgad VW MKIV-A4 TDIs (VE and PD) 15 January 19th, 2005 12:26
How long does the battery last? dkuster VW MKIV-A4 TDIs (VE and PD) 19 December 3rd, 2004 11:07
Page generated in 0.18875 seconds with 11 queries
[Output: 125.95 Kb. compressed to 104.59 Kb. by saving 21.36 Kb. (16.96%)]
