Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old December 10th, 2017, 14:39   #46
crawdaddy
crawdaddy's Avatar
Originally Posted by kirky00 View Post
Completely getting out of WV's for a while, parting out my 2001 golf TDI 5 speed and all the parts i've collected over the years. Willing to ship on at buyers expense, or meet me in Sudbury on December 15th, can bring anything up with me then. all parts located in Cochrane Ontario.
-PP520 injectors balanced and pop tested $300 PENDING SALE
- Stock 5 speed injectors 330K $20
- 2 x 11mm pump $300 each
- 10mm pump 300 K needs top cover seals $100
-10mm pump CORE only FREE!
- 3 bar map sensor $20 - SOLD
-Intercooler with factory map sensor $30
- Upper and lower charge pipes $40 for the pair
- VNT 15 turbo 250K on it, no shaft play $100
- ARP head studs $80 SOLD
Kerma VNT 17 adapter $20 comes with the lower charge pipe already cut to fit.
-Intake manifold, clean and comes with EGR delete pipe $50
-2x intake manifolds that need to be cleaned $20 each
- Southbend stage 2 daily clutch/flywheel 100k $400
- 5 speed manual trans, no grinds and shifts great $250 or $350 for a complete auto to manual swap with out clutch or $700 with a south bend stage 2 daily w.flywheel
-ALH engine running but has a misfire, has 300 KMís, new timing belt kit $200
ALH complete engine with 500 KMís, block and pistons are in great shape, needed head gasket and timing belt service when pulled, comes with accessory bracket and PS pump $100
ALH complete engine, 300 KMís, had a broken timing belt when pulled, 3 lifters and the cam were damaged, other then that its in good shape $100
- 5 speed manual trans 370KMís on it, Needs and shift tower for sure $40
-2 wire glow plug harness bran new never used $40
-ABS pump $20
-Rear axle wheel bearing stub NEW $20
-Rear drivers side dust shield NEW $5
-Glove box, big style in mint shape $20
- Good year Nordic winter studded tires on factory Volkswagen rims 205/65R15 $400 Also have black steel rims in 5x114.3 and 5x112 that i can have these tires mounted on.
- Volkswagen rims 15í with some bald general tires 195/65R15 $80
- Frost heater for a manual ALH $60
- Cloth interior FREE
-Kerma VR6 springs 200KMís on them front ones come with KYB gas shocks $80
- Sub frame with lower control arms, audi TT bushings and new greaseable ball joints, can come with steering rack with tie rods as well $80
I'm interested in some parts. I emailed you, please check your email and reply ASAP. Thank you
crawdaddy is online now   Reply With Quote
Old December 15th, 2017, 06:15   #47
TDIFred
TDIFred's Avatar
Fuel Economy: 64, 60, 48
Oil Fuel Cabin Air filters for 09 Sportwagen 50$
Front Rotors and pads - brand new. $150
2015 Tiguan (no diesel)
2009 Jetta Sportwagen TDI (gone)
1993 Ducati 900 'Black Monica' (California)
1994 Ducati 900 Supersport Red
2014 Ducati 899 Panigale Red
TDIFred is offline   Reply With Quote
Old December 17th, 2017, 16:33   #48
HPsenicka
Update....
2) Four 16" 5 x 112 steel wheels, naked (no tires mounted), minimal rust
removed from a 2011 Jetta
Reduced - Asking $50
Originally Posted by HPsenicka View Post
I have two sets of 16" steelies available for you to choose from.
1) Four 16" 5 x 112 steel wheels with Gislaved 205/65-16 snow tires.. tires near end of life (almost down to wear bars), but could possibly still be useful
removed from a 2006 Jetta MKV
Asking $50 - SOLD
Asking $75
3) Four 15" 5x100 steel wheels , naked (no tires mounted)
removed from a 2004 Jetta MkIV
Asking $40 - SOLD
HPsenicka is offline   Reply With Quote
Old January 1st, 2018, 17:09   #49
burn_your_money
TDI(s): none
WANTED
1) ALH cam lock tool that you can use with the valve cover on
2) Timing belt tensioner tool that will work with the motor mount installed
Price shipped to N0J1B0 please
I buy core TDI pumps. PM me for details
burn_your_money is online now   Reply With Quote
Old January 1st, 2018, 17:16   #50
maxmoo
Originally Posted by burn_your_money View Post
WANTED
Many used timing belt tools for sale...
http://forums.tdiclub.com/showthread.php?t=484927
maxmoo is online now   Reply With Quote
Old January 2nd, 2018, 13:33   #51
KARKS
KARKS's Avatar
Fuel Economy: 1090/980/870
Default Pads and Rotors - NIB
Cleaning out the garage and found that I have Pads and Rotors brand new the box for a 2011 golf wagen. Can send pictures. asking $275. I am in Wasaga Beach but travel to Mississauga weekly (can deliver within reason).
Fronts - Brembo Rotors
Rear - Wearever Rotors (Carquest)
Brake Pads - Motor Master (4) and Wearever Gold (4)
2011 Golf Wagon TDI DSG Platinum Grey 240,000km (Bought Back by VW)
2004 Jetta TDI 5 Speed Black 360,000km **SOLD**
[B][FONT=Palatino Linotype][COLOR=#ff0000]
KARKS is offline   Reply With Quote
Old January 3rd, 2018, 06:48   #52
TDIFred
TDIFred's Avatar
anybody want a Euroswitch? controls aftermarket fogs. I can swap it out in seconds. this ad will disappear after 1300h today.
anyone want side window deflectors, front, from WeatherTech?
Old January 3rd, 2018, 11:49   #53
burn_your_money
TDI(s): none
Thanks. Still looking for the cam lock tool.
Old January 9th, 2018, 16:08   #54
breakfasteatre
For sale: located downtown Toronto. Can meet near Mccowan/Steeles as well
Cleaned Alh intake manifold: 60
Cleaned egr valve: 60
Cleaned egr cooler: 60
Egr delete pipe with gasket: 10
Passenger side coolant and power steering line from reservoirs: 20
breakfasteatre is offline   Reply With Quote
Old January 19th, 2018, 21:36   #55
Uberhare
Uberhare's Avatar
Fuel Economy: Depends on what I'm towing!
H&R lowering springs. B5 Passat 54774-2. New in box, never used. (Sedan models front: 1.6" rear: 1.5") (Wagon models front: 1.3" rear: 1.25")
$200
2005 Passat BHW Variant w/01E 6 gang
"Pilots - looking down on the world since 1903!"
Uberhare is online now   Reply With Quote
Old Yesterday, 16:25   #56
2.2TDI
TDI(s): .
Originally Posted by 2.2TDI View Post
I am looking to get a set of 17 or 18 inch OEM VW rims for when summer comes. That said, I have a set of OEM 16 inch Toronto rims with contiprocontact tires. Tires have 45000km and are the factory tires that came with the car. Don't have the exact tread depth of the tires as they are currently stored but can find out for anyone interested in a trade. That said, if anyone wants to do a trade, let me know what you have and how much extra you would like on top. Below is a reference to the rims i have
https://images.wheels.ca/wp-content/...2017-main1.jpg
Bump. Sold my 16's, now I need summer rims and tires
2.2TDI is offline   Reply With Quote
Old Yesterday, 20:34   #57
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
10:30pm EST or 9:30pm CST where I am and still there.
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.Average 1 year 30/6/16 to 30/6/17 - 50.71 Mpg - 5.56 L/h
Jetta_Pilot is online now   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Uberhare
Page generated in 0.15054 seconds with 11 queries
[Output: 112.47 Kb. compressed to 94.67 Kb. by saving 17.80 Kb. (15.83%)]
